OIL - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-04-2009, 08:25 AM Thread Starter
FastFocus's Avatar
OIL
does anyone know what kind of oil the Ford Dealer uses when they do oil changes on the PSD's? is it synthetic or what?
the reason i ask is i've got an oil change coming up, and i'm going to do it myself, however me and my dad share the truck a lot since we both travel towing and when he is out of town traveling he takes it to the dealer for an oil change. the dealer has done it up to this point, 48k miles on it now. and at 50k miles i'm due.
i'm wanting to use Mobil 1 Synthetic Diesel oil, but i know you're not supposed to go back to dyno oil from synthetic in a gas motor. is that true with diesels? is the oil ford uses synthetic?
i just don't want to use synthetic now and have him take it to the dealer and throw in their motorcraft dyno oil.
thanks in advance!
-Aaron
'07 F-250 PowerStroke - 5" MBRP Straight Pipe, Edge Insight, Eric Tuned SCT, HID's, 2.5" Newton Lift w/ 4" rear block and Icon Caster Sleeves, Bilstein 5100's, 18" XD Monster's w/35" Toyo M/T.
'01 BMW ///M3 - Weekend Toy
'17 Chevy Malibu - DD and Company Vehicle
FastFocus is offline
post #2 of 3 Old 02-04-2009, 11:49 AM
AFBLUE's Avatar
I am sure the standard oil is Motocraft 15w40. Synthetic oil really isnt going to do what its worth unless you run it with a bypass oil system, and extended drains.
I know it feels good that you are doing more for your motor using, expensive synthetic oil, but unless you are running it extended periods, or a lighter weight like 5W40 for cold climates.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #3 of 3 Old 02-04-2009, 01:08 PM Thread Starter
FastFocus's Avatar
the truck is used mostly for hauling, would i get better MPG's out of the Mobil 1 5w-40? its cold enough now to use it for the cold climate but in about a month it will be warm again.(at least i hope )
-Aaron
