Disabling the 'dinger' - Ford Powerstroke Diesel Forum
post #1 of 55 Old 12-27-2006, 11:00 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
I'm trying to work on my rig and I want the radio on but I can't find the key in the ignition "dinger" to disable the sucker. Does anyone posses the secret as to where Ford has hidden this thing in my rig? The fawker that designed it must work for the CIA and is used to hiding bugs in terrorist vehicles because I can't find it. MAKE THE BEEPING GO AWAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
'05 F250, CC, FX4, 6.0 PSD
sct x4
MTW Stage 1 Turbo
DJ's FUEL+ - Fuel Pressure Intensifier
Nitrous Express NXd Stacker
Snow Performance Stage III Water/Meth Kit
ARP Studs
MBRP 4" Turbo Back w/ no Muffler & no Cat
DashBoss on my iPad
ISSPRO Gauges in Triple A-Pillar
High Idle Mod
Iron Horse Front Bumper Replacement
12,000LB MileMarker Winch
2000Watt Power Inverter
Viper 5901 Remote Start/Alarm
Pioneer Avic-D3 Stereo/Nav
Train Horns!
Valentine 1
Velvet ride shackles
RockStars on 33's
Big azz dent from a blown tire.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #2 of 55 Old 12-27-2006, 11:05 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
You know of course, if you disable the dinger, you will lock your keys in your truck the very next time you drive it....
I hate the dinger too but more than once, it has reminded me that my keys were still in the ignition before i locked the truck up....
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 55 Old 12-27-2006, 11:07 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
But I lock it with the alarm remote attached to the key so I should be fine.....famous last words.
Seriously though I'll take my chances to get rig of that DINGING!!!!!!!!!!!!!!!
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #4 of 55 Old 12-27-2006, 11:08 AM
The Fat Mod
Logan's Avatar
Well, you have a key pad for that right?
Logan is offline
post #5 of 55 Old 12-27-2006, 11:10 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
Yeah - that's a good point. I really don't use it since I got the alarm/remote start put on. Everything is controlled by the key chain.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #6 of 55 Old 12-27-2006, 11:13 AM
duct tape & zip ties
bigcountrysg's Avatar
Disabling the "dinger"
Ok yall this is what yall gotta do. Pull the ignition switch out. There is a black wire that goes to it. Unplug that wire from the ignition switch. Put some black tape on it leave it unplugged and put the ignition switch back in. That wire I believe is a ground wire witch activates the dinger. at least that is how I got it to be disabled on my truck it is a 02 F-250. To remove the ignition switch put the key in run position. Then on the bottom of the steering column there is a little hole right under the ignition switch. You need a small phillips head screw driver push it up into that hole. Then you can easily pull the ignition switch out and unplug the wire from it. The reason for the black tape is so it will not make contact and have the dinger go off while your going down the road. This takes a whole whoppin 5 minutes.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #7 of 55 Old 12-27-2006, 11:23 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
What happned to the gold 'ol days of just pulling out the buzzer???
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #8 of 55 Old 12-27-2006, 11:35 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
Cool - that sucker just pops right out but I don't have any wires. It's all encased on the ignition itself. Let me pull the cover off the steering column.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #9 of 55 Old 12-27-2006, 11:36 AM
Slappy's Avatar
I disconnected my seatbelt dinger and I think the door dinger quit also. Right under driver seat. I will have to check next time I have the door open and the key in. I know the light dinger still works.
Slappy is offline
post #10 of 55 Old 12-27-2006, 11:39 AM
Disabling the "dinger'
Hey Rodslinger, it has been awhile since I did this. You maybe correct about having to remove the steering wheel cover. either way it is on the bottom mine had a little red with silver metal tabs on it. That the wire plugged into. That red plastic piece with the silver tabs made contact with the ignition switch. All I know is that when I disconnected that blace wire the dinger stop.
2002 7.3L burnt
