How bad is this???
I plan to get it fixed, but curious as to how bad this may be, or what else could be wrong. It looks like the compressor is leaking oil around the ring on the exhaust side, and I see oil residue at both ends of the intercooler hose, that also exposes some residue on the frame at the front connection. Is there a seal in the compressor that can be replaced? What is this oil doing to the compressor or down line components?
It's my wife's '03 Excursion with the 6.0 and it drives fine, but when I checked the oil, I noticed all of this. Are there trends, or common parts that fail in this area? Thanks. |
Sorry, I just noticed I probably posted this in the wrong section.
Could I get a moderator to move this to the problems section please?
The oil comes from the crankcase vent line (I think its called the CAC) that is plumbed into the intake on our trucks. There is a mod to remove the line from the intake and direct it out on the road (too messy for me), or you can get with NChornet, he has a nice kit that takes the CC vent line and sends it through some kind of filter, and then back to the intake, free of any oil. It will eventually get such a build up that it will start to leak in the valley and come down your bell housing, looking likt a rear main seal leak.
On edit, not a CAC, its a CCV. Thanks dhanna6powerstroke Last edited by 2006PSDSD; 02-03-2009 at 08:18 AM. Reason: oops |
So, nothing to really worry about???
Should I take the cac tubes off and clean things up? What about the flat portion of the compressor around where the bolts are, it appears to leak around there as well? Is there a seal or gasket that I should replace, or would I stir up more harm? Does any of this contribute to the EGR caking up? Should I take it off and clean it? I'm do for a oil change this weekend anyway. If so, where can I get a new o ring? |
I was always curious what that stood for, thanks
