I am new here to this forum, and am glad to have found you guys...it's fantastic. I have a 2004 F250 company truck that is at the dealer in need of a new EGR cooler and a has a hose going to the turbo that is blocked. They want $5400.00+ to fix it. Can I get the cooler and install it myself to save some jack. And is it a dealer item? Thanks again for all your help.
The dealer that my company usually uses is about 100 miles away. I would like to fix it myself if I could get the kit.
thats way to high for a egr cooler job , why do you think you need one ?
I noticed coolant dripping from the back of the engine off the starter. I took it to the dealer and that's what they said. They said it is leaking internally and externally, which they say is causing the lack of power on take off issue. By the way, thanks so much for all the info. Can I use this delete kit on a vehicle used on the road?
Mine has a power issue, and shudders when you let off the throttle. Once it shifts thru 4th gear, it seems to be ok, but has no passing power until it shifts back up. But it is definetely leaking coolant. And they said some hose for the turbo is blocked. I have never put a wrench on one of these engines, but have been a mechanic all my life, so I think I can fix it if I know what it needs.
No, there is no coolant coming out of the bottle. I will pull the EGR valve and clean it. It was replaced when the thing had about 70,000 on it under warranty, and now it has 145,000. No real issues till now.
