po 300 & 301 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-27-2009, 02:15 PM Thread Starter
DESERTEAGLE50's Avatar
po 300 & 301
had these codes pop up should i be worried???? random misfire
2006 king ranch,8" fabtech lift,37" procomp e/t,magnum force cold air intake,6"bull hauler stacks,sct innovative custom tunes,zoodad mod,
DESERTEAGLE50 is offline
post #2 of 7 Old 01-28-2009, 06:45 AM Thread Starter
anybody????????????
post #3 of 7 Old 01-28-2009, 06:52 AM
A P0300 OBD code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
99 Ford PSD F350 7.3L
AFE stage II cold air intake
MBRP 4" turbo back exhaust with 4" down tube and
"5" SS tip
ktfjammer is offline
post #4 of 7 Old 01-28-2009, 06:55 AM
anybody????????????
Do you have any symptoms of any misfire? If not try to reset and see if it comes back.
"5" SS tip
post #5 of 7 Old 01-28-2009, 07:14 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Did you get it when the truck was cold?
dhanna6powerstroke is offline
post #6 of 7 Old 01-28-2009, 01:44 PM Thread Starter
truck was warmed up & no symptoms of misfire ! it's funny ever since i started using my sct tunner i started getting crazy codes !! not saying it's that. so i'm going to put stock tune back in and see what happens.
post #7 of 7 Old 01-28-2009, 01:59 PM
Mod Newbie
Quoted: 20 Post(s)
I know a lot of the misfires in the 6.0 had to do with the electronics of the injectors. Mostly in the 03 year and some 04. Not sure what is causing it, but I can't imagine the SCT causing it but anything is possible I guess.
