Torque Specs and Leveling Kit Install Info?
I have a 2" leveling kit for my F-350 is there a file or ref for the torque on the swaybar and coils? I am also looking for any info from anyone that has done this themselves? Can I do or do I need a coil compressor? Thanks for any and all help.
Make them tight and use red lock tite if you have the lower spacer kit.
I did the spacers on top of coil and it was taking the clamp on the brake line loose and the sway bar loose. I just jacked up the truck and put jack stands behind the radius arms and lowered the front axle back down. I used the Pro comp kit and the directions were easy for me to understand.
