Unit bearing or Hub conversion - Ford Powerstroke Diesel Forum
Old 01-26-2009, 07:16 PM
Im in need of either a new unit bearing or a good inexpensive hub conversion kit. Which would you do and where can I find a good hub conversion kit or a good heavy duty replacement unit bearing. For an 06 f350 4x4 it just started making noise but no play yet how long will my unit bearing last.
Old 01-27-2009, 12:56 PM
Bump!!!!!!!!
Old 01-28-2009, 12:56 PM
I drove it today and when the wheel was turned left and when backing up from the drivers side front tire I heard pop,pop,pop so could this be a u joint. not a wheel bearing. BTW I was in 4x4.
Old 01-28-2009, 01:00 PM
duct tape & zip ties
Were you on dry pavement. Either way check your u-joints on the front axle at the steering knuckle.
Old 01-28-2009, 03:55 PM
It was hard packed snow.
Old 01-30-2009, 12:31 PM
bump!!!!!!!!!!!!!!
Old 01-30-2009, 12:44 PM
mine makes a click click click sound while driving in or out of 4wd could it be the same thing. unit or ujoints?
Old 01-30-2009, 12:47 PM
<-Day Of Fail now SOLD
I just had a similar prob, changed out my stock auto/locking hubs for a set of Warn Premium set. Now all is good. Myabe you might have the same problem, but Warn Premium's won't work or your 06
Old 01-31-2009, 06:18 AM
Why would my hubs be making noise in 2wheel.
Old 01-31-2009, 06:20 AM
Mine sounds kinda like the tires rubbing the mud flap in 2 and 4wheel when turning left and it goes pop pop in reverse when wheels turned to left on the drivers side.
