03 EX headlamp to 05 + swap
This was posted in another section with no answer. Does anyone know if this is true?
Originally Posted by cobra4v04
Back to the headlights. I'm reading now that with the swap to the 05'+ headlights I will lose my daytime running lights as well as control of the factory foglights with the factory headlight/foglight switch?
The simple harness upgrade from dfuser runs around $50, and apparently the harness upgrade that allows use of daytime running lamps and fogs runs around $150, but it still doesn't allow use of the factory headlight switch to operate the fogs?
Am I fairly accurate on this? Seems to be a bit more involved than just swapping lights and a cheap harness to retain total factory control.
anyone know the scoop on this? why would this change anything all you are changing is the bucket and pigtail for the new bulbs right?
