intercooler boot - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-23-2009, 07:43 PM Thread Starter
hagemasta's Avatar
intercooler boot
blew a intercooler hose today any help on how to keep it for comming of would be a great help thanks.please:
hagemasta is offline
post #2 of 5 Old 01-23-2009, 07:50 PM
Shaking the Bush Boss
CHUCK's Avatar
on the end of the pipe/ intercooler...scuff it with sand paper. Also try spraying hairspray on the ends. Youd be surprised how well it holds.
Chuck
CHUCK is offline
post #3 of 5 Old 01-23-2009, 07:50 PM
Rice Hunter
Diesel Freak's Avatar
It's prolly blowing off due to oil. Clean it good and put it back tight. If it continues to blow off try spraying tube with hairspray. Makes it sticky/tacky
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #4 of 5 Old 01-24-2009, 09:46 AM Thread Starter
hagemasta's Avatar
thanks guys will try it
post #5 of 5 Old 01-24-2009, 10:57 AM
Clean the boots with very hot soapy water. Let them soak for a little while (15-30 minutes) Dry them really good. Clean the areas that they mate up to really well. Use a bit of hairspray (not too much, and put the boot on immediately before the hairspray dries). Tighten the clamps really good. Last step - put your foot in it and don't worry about them!. hehe Good luck
2004 F250 CC SB 4x4 Lariat
WIX intake with zoodad mod
(05 & up) Innovative Diesel intake elbow with butterfly valve manifold removed
4" SS T-Back no kitty exhaust
SCT X3 w/ I.D. Custom Tunes
Gauges: EGT, Boost, Tranny Temp
Pace Edwards bed cover / B&W Gooseneck Hitch / Linex
DieselSite coolant filtration system
DC Power Engineering 250A Alternator
Submariners do it deeper!!!
ShawnCT450R is offline
