Well she is a Puker. Whats Next? Help?? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-19-2009, 04:50 PM Thread Starter
muddy650's Avatar
Well I was hauling a 30 jobsite trailer back home the other day and my 06 started puking and whistling like a little teapot. Thought I was doing good by going back to a tow tune. Now everytime I get into her a little she makes the teapot sound. I have already started the process on getting some stuff. Here is what I have in mind.
Arp Headstuds
Motorcraft Headgaskets
Get the heads machined
Full EGR Delete
Injectors????
O.K. so what else needs to be done while I am in there. I would like to go with some injectors maybe. I need some that I can use with my stock turbo, but when the time comes that I can put with an aftermarket turbo and make some real power.
2004 F250 CC SB
SCT Xcal2 SPD+ Lonney Wild Track
ARP Studs
PHP FICM Tuner
2003 Turbo
Coolant Filter
EGR Delete
4" Magnaflow
Airaid Intake
Zoodad
Blue Spring
6.4 Banjo's
CAT EC-1
Custom Camo Seat covers
muddy650 is offline
post #2 of 8 Old 01-19-2009, 04:54 PM
Get the heads checked for cracks.
2005F250 is offline
post #3 of 8 Old 01-19-2009, 04:55 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Arp Headstuds
Full EGR Delete
Injectors????
Are you under warranty?
dhanna6powerstroke is offline
post #4 of 8 Old 01-19-2009, 05:06 PM Thread Starter
muddy650's Avatar
Yes but none of the dealers around her will put nothing other than stock bolts back in. I have a best buddy that is a mechanic and he said he would do whatever I wanted, if I would pay half on a lift for his personal shop. Which will be like $700 plus parts for my truck.
2004 F250 CC SB
ARP Studs
PHP FICM Tuner
2003 Turbo
Coolant Filter
EGR Delete
4" Magnaflow
Airaid Intake
Zoodad
Blue Spring
6.4 Banjo's
CAT EC-1
muddy650 is offline
post #5 of 8 Old 01-19-2009, 05:10 PM
Mod Newbie
Quoted: 19 Post(s)
Well in that case, I would definetely have the heads checked. Both mine were cracked. I wouldn't worry about injectors unless you go ahead and do the turbo. If nothing else, I would have Ford do it and then do it yourself after they are done, just for the simple fact that if the heads are cracked you can't walk into Ford with the heads and get them to replace them.
post #6 of 8 Old 01-19-2009, 05:12 PM
work&play's Avatar
Quoted: 2 Post(s)
I am in the same boat with the HG and just ordered ARP's a ITP regulated return,EGR delete and a set or coolant lines (seems like a go idea and not to much $150) for the heads from Elite
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #7 of 8 Old 01-19-2009, 05:15 PM
Mod Newbie
Quoted: 19 Post(s)
$150 for what?
post #8 of 8 Old 01-19-2009, 06:02 PM Thread Starter
muddy650's Avatar
Any dealers on here wanna make a package deal on Arp's, headgaskets, and egr delete??
2004 F250 CC SB
ARP Studs
PHP FICM Tuner
2003 Turbo
Coolant Filter
EGR Delete
4" Magnaflow
Airaid Intake
Zoodad
Blue Spring
6.4 Banjo's
CAT EC-1
muddy650 is offline
