zoodad works for me! - Ford Powerstroke Diesel Forum
post #1 of 24 Old 01-17-2009, 04:12 AM Thread Starter
lifetime member
well, i finally did it. i noticed a big drop in egt's when i installed the intercooler. i did the zoodad last weekend and now my egt's are 675 at 75 mph. that is while running erics stud tune. they started out at around 900 degrees, dropped to a good solid 775 to 800. after zoodad they dropped to 675. i am sure that winter helps some. it is finally chilly down here. it got to 24 this morning. oh, side note: if it is below 80, i am freezing!!!!!! lol.
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #2 of 24 Old 01-20-2009, 09:33 PM
So if I'm reading this right, you noticed almost the same drop in EGT from the Zoodad as you did from an aftermarket intercooler? What kind of drop did you notice when you got rid of the EGR system? 675 while cruising down the highway is good! Have you towed with it yet?
dc3655 is offline
post #3 of 24 Old 01-20-2009, 10:47 PM
AFBLUE's Avatar
it took you this long to do it? i hacked mine the first day i bought it!!
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #4 of 24 Old 01-21-2009, 07:13 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Mine runs about the same or cooler at 75-80mph. I really have to be pushing it up a mountain grade to see over 1000 degrees even briefly. Currently running a looney tune.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 24 Old 01-21-2009, 09:30 AM
Deere Diesel Man's Avatar
Feedback Score: 4 reviews
Would you mind to take a picture or anyone of the zoodad mod?
Deere Diesel Man is offline
post #6 of 24 Old 01-21-2009, 10:42 AM
AFBLUE's Avatar
zoodad mod
Scroll down and will show you how to take grill off, then its just cutting a hole in the front radiator deflector.
I have found a dremel with a spiral zip bit works best, pull back rubber cover between rad and front clip so you can stuff the intake plenum with a towel, then just start cutting away. Take a sanding bit to clean up the edges, pull towel out of intake and vacum up dust.
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #7 of 24 Old 01-21-2009, 11:08 AM
Thanks AFBLUE for the info. I might just do that tonight!!
post #8 of 24 Old 01-21-2009, 11:29 AM
Yeah, that's a nice clean job and my truck is in need of this too! I liked the looked of the SS in the other thread.
dc3655 is offline
post #9 of 24 Old 01-25-2009, 12:30 PM Thread Starter
lifetime member
yes. 3,000 to 3,500 lbs on stud tune in the flat lands of florida and it did not change it.
post #10 of 24 Old 01-25-2009, 01:17 PM
I did my zoodad this weekend as well as the air box mod...
Just had heck tryin to get the grill off so I had to do the zoodad from under the hood... Not pretty, but I got it done, sanded and cleaned up...
TxOutlaw is offline
