swap an auto tranny to a standard - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-16-2009, 01:01 AM Thread Starter
i have a 03 f 350 and was wondering if i would be able to swap my auto tranny to a standard one what problems would i come to?
any help ?
brosette is offline
post #2 of 3 Old 01-24-2009, 06:35 AM
zspear1's Avatar
It can be done but you need a wreck that has all the good parts. You'll need
drive lines trans mount flywheel clutch assembly steering column, pedal assembly, floor carpet kit for manual, Manual trans, T case for manual, any new wiring harness, (not sure what the ECM will think may need all that too). and what ever else you run into.
2006 crew cab XLT, Fx4 6.0 stroke, torqe shift trans, deleted EGR, Turn over ball GN.
zspear1 is offline
post #3 of 3 Old 01-24-2009, 06:39 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
is your truck a 2wd? If so, coalrollinroostercruiser has a good 2wd manual ZF-6 that he will sell really cheap. he needs a 4wd Trans. PM him if you need it.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
