Tired of this POS truck - Ford Powerstroke Diesel Forum
Old 01-12-2009, 11:33 PM
Damm death wobble came back the other day, dont even wanna drive this POS anymore, should have just bought an 03-04, my buddies never had this issue with leaf springs all around. Is there any REAL fix to this damm problem, i see even stock trucks get.
Mods are: 8in fabtech radius arm lift kit
Procomp Res. shocks
Fabtech 5.5in leafs in the rear with f350 block
Dual stabalizer
I just got the damm truck alligned about 7k miles ago, and it recently started wobbling a tad bit which it would always do at times, since the suspension is so stiff, and i fell every little thing on the road, then the other night it did it to the point i had to slow down on the freeway to about 30mph.
PLEASE: Is there a Solution to this crap?????
Old 01-12-2009, 11:40 PM
Have you talked to Nick at nor-cal truck in livermore? He may be able to help. He is a sponsor of the site.
Old 01-13-2009, 01:21 AM
Your stabilizers are wore out. I had the same death wobble problem with mine. replaced them with superlift superide dual stabilizers and has not wobbled since.
Old 01-13-2009, 12:43 PM
i actually put my old front shock on in place of the stock stabilizer, its workd until i got a reall one.
Old 01-13-2009, 12:48 PM
im running stock stabalizer and procomp dual stabalizers as well. truck only has 30k miles lifted for about 7k miles
Old 01-13-2009, 12:51 PM
You might need alignment cams so you can adjust your castor
Old 01-13-2009, 01:07 PM
Your track bar is probably loose. Take it off and sand the paint off the tracbar mount were it bolts too and then reinstall and torque to 430 ft lbs.
Old 01-13-2009, 01:24 PM
Granted I am only running a 6" lift on my '06 but I had the death wobble and I finally got rid of it. This is by no way a cure to your problems but might be a start. Steering stabilizer x3(2 pro comp and the factory), Track bar, ball joints x4, caster cams. Thankfuly it was all under warranty except the 2 pro comp stabilizers.
Old 01-13-2009, 02:38 PM
If your caster is on point like its supposed to be, wobble is almost always due to worn out steering parts. Also check your steering gearbox freeplay.
Old 01-13-2009, 06:02 PM
check the tires are they cupped?my truck did that bad and it was cause of the tires and they only had about 5000 miles on them just a suggestion
