Dilema with stacks - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-12-2009, 10:25 AM Thread Starter
Dilema with stacks
I wanna put stacks on my truck at least 5 in but i have a transfer tank in back for work purposes. there is 8 inches of clearance between bed rail and tank. Is this enough room to install them with out causing problems? Any advice will be appreciated. Also i pull a fifth wheel that has been converted to a goose neck couple will this interfere with turning?
Stroking the oilfield is offline
post #2 of 18 Old 01-12-2009, 10:30 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
What size pipe are you using for the bed kit or y-pipe?
-Julian
4th 6.fo
TwinTurboStroker is offline
post #3 of 18 Old 01-12-2009, 12:28 PM Thread Starter
Really don't know just want 5 inch coming up. I am running 4 inch under neath right now. If i have to run the Y between front of bed and tank i only have 2 inches of clearance so it would be impossible. and i am not running single stack.
post #4 of 18 Old 01-12-2009, 12:50 PM
Let's Run'em
Quoted: 10 Post(s)
Well if you go with a 4" bed kit you should be fine, you'll be close but fine. To be sure I would measure how much room you have with your tank and then get under the truck and see how much room you have between the bed floor and front of the bed
-Julian
4th 6.fo
post #5 of 18 Old 01-12-2009, 12:51 PM
symbols's Avatar
Here is how I did mine but I don't know if this will work with your tank....
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #6 of 18 Old 01-12-2009, 12:58 PM
symbols's Avatar
Here is a better pic of what is holding everything..
Jason
symbols is offline
post #7 of 18 Old 01-12-2009, 01:05 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
i think 8" would be enough clearance. Get everything as close to the bed front as you can and maybe you'll only need about 7" total clearance.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #8 of 18 Old 01-12-2009, 01:13 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
Yeah I think 8" will be plety of room. I have 7-8" of clearence between my bed and toolbox and my stacks fit fine.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #9 of 18 Old 01-12-2009, 01:13 PM
SuperCrutyPS's Avatar
Quoted: 305 Post(s)
Garage
Not wanting to throw a damper on plans for your truck. R U sure you wanna run stacks with your 5er?
I pull one also. I'd be afraid the sides of my 5er would end up looking like some of the 18-wheeler trailers. Like most of us, I like the smell of diesel - I'm just not sure I want it floating around inside. I just put a turn-down tip on my 4" exhaust because I was getting soot on the right side skirt with my straight tip. It was a pain in the backside to get off.
Just mentioning it as something to consider. Obviously, it's your truck.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #10 of 18 Old 01-12-2009, 01:17 PM
symbols's Avatar
Yea, if whatever you are towing is white and it rains...it will be black and it's not fun to get off of camper. I spent 2 hrs scrubbing soot off and never even touched the roof.
Jason
symbols is offline
