Oil filter heads up and a CAUTION - Ford Powerstroke Diesel Forum
Old 01-09-2009, 02:10 PM
I've been using the Fram CH9549 oil filters (which were repackaged Racor filters) for 2 or 3 years now. Went to Chinamart to pick up a filter, snatched the box off the shelf, paid for it, and out the door. I thought....I better double check to make sure it's the correct filter. Low and behold......South Korean made who knows WTF kind of will fit filter was in the box. It had a white fuzzy seal on the end instead of the the yellow Racor felt seal and none of the Pat. Pending numbers on the end, so unless someone pulled a quickie on Chinamart and switched and returned an A/M filter for a Fram then maybe Fram has switched again.
Old 01-09-2009, 05:12 PM
Slacker
Feedback Score: 4 reviews
Hmmm. Mine from Chinamart CH9549 was the original and I just bought it over last weekend. Hopefully, they aren't changing to something else and I just ended up with the Racor because it was still in distribution... Thanks for the heads up, Tim. I'll keep my eyes peeled.
PS. Oh, but I did develop a slight oil leak from the oil filter cover, despite replacing the o-ring. Maybe my filter was the original, but I got the South Korean o-ring!
Old 01-09-2009, 05:42 PM
I still can't believe they charge us $20 for a oil filter.....
Old 01-09-2009, 07:23 PM
i thought it was bad to use any other filter the motorcraft do to the size difference.
Old 01-09-2009, 11:38 PM
The Motorcraft filter is made by Racor, and the Fram CH9549 is also the same Racor filter (just in a different box).
And if you keep an eye on the Pep-Boys sales ads then you can get them for (2 for $7) several times a year!!!
Old 01-10-2009, 03:46 PM
Wow... this is new to me too... Thought fram was a no no too!! Yea, I buy the motorcraft at wally for 19.00 er something... What I wish is to find the fuel filters cheaper... replacing those every 10K can get pricey!
Old 01-10-2009, 04:34 PM
If its actually a fram filter then its garbage but someone stumbled across it and found that the 6.0 filter is all the same as stated above.
Old 01-11-2009, 09:15 AM
You can get the fuel filters from an IH/Navistar dealer for $29-$40 dollars. If you don't know the part# (I don't have it offhand) ask for a fuel filter for a VT275. There will be 2 filters and 2 sets of o-rings in the IH box.
Old 01-11-2009, 09:29 AM
went to walmart last night and saw that they had both the motocraft, and the fram filter, for now they are still the same in my area, but WTF they are only $1 less 18.44 vs 17.44
