Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 01-06-2009, 03:56 PM
Crank case vent MOD
OK so i am finally goin to do this i think...lol
So correct me if I am wrong...I will need some 3/4 inside diameter rubber hose, some hose clamps, a crank case vent filter a 5/8" id to 1/2" barb fitting (brass)? Get me straight on this guy's thanks!
Where did you guy's get your tiny ccv filters???
Old 01-06-2009, 04:15 PM
i just took a peice of 3/4 inch hose and a clamp and ran it under the truck like the blow by tubes on the cummins.
Old 01-06-2009, 04:21 PM
I ran mine all the way back to the tailpipe and put my fitting in at an angle so under load it would draw out the pressur it works well .I had a puke can for awhile but I hated the smell at idle so I ran it all the way to the rear. I used a plastic 3/4 90* fitting up at the seperator on the VC. I pluged the hole in the airfilter tube with a huge bolt cut off flush and jb welded in place. I have an intercooler on my OBS so I did this to keep the oil out of it.
Old 01-06-2009, 04:25 PM
Obama sucks
Nice to see you over here man
Thanks man.
Old 01-06-2009, 04:30 PM
Do you have any oil on the rear quarter panel? Or is the amount coming back that far minimal? Wasnt there a write up with pics on this? I searched but couldnt find anything.
Old 01-07-2009, 08:43 AM
Where are you guys gettin those tiny little ccv filters?
Old 01-07-2009, 08:57 AM
Slingshot Engaged
if you want a sweet set up contact NCHornet on here. He can hook you up!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
