wires from 04 to 08 mirrors? - Ford Powerstroke Diesel Forum
Old 01-01-2009, 08:52 PM
Bought a set of 2008 Super Duty mirrors and wanted to see if there is anyone here has did the wiring from the 04 Lariat to the new 08 mirrors. So simply need to now how to hard wire them in so they will work. Thanx
Old 01-03-2009, 08:24 PM
If someone has a ford service manuel I could use a wiring diagram for a 04 and a 08
Old 01-03-2009, 08:26 PM
<<---"Shadow"---
Subscribing. Interested myself.
Old 01-03-2009, 08:33 PM
Feedback Score: 5 reviews
My truck's a 99 but the only wires that I had to run into the cab were the parking lights and turn signals. I think the wires off the new mirrors were, power, ground, parking lights, turn signals, heat and adjust. Raul sent me the wiring diagram but I think I deleted it. It's on here somewhere, I'm pretty sure I've seen it.
Old 01-03-2009, 08:39 PM
Any way to make the power extend and fold work also?
You said yours is an 04 and this is for an 05 but maybe this will help.
Originally Posted by BUKWAKR View Post
if you have a 05-07 this is how I did mine, cut the old plug from the original mirror leaving about 9'' of wire then cut off the plugs on the 08's leaving about 6'' then go wire for wire all the colors are there. The only difference is there is two yellow wires on the 08's just put them both to the single yellow on the 05-07 plug. Solder the connections then heat shrink them reinstall and enjoy. As mentioned earlier in this post the switchs will work in reverse.Everthing else will work the same.
good luck
Darrell
If not, here's a thread w/pics
'08 mirrors on an older superduty
Old 01-03-2009, 08:41 PM
yes... but it will take some wiring...
its not too hard if your good at it
Old 01-03-2009, 09:02 PM
I'll take mine apart in the mornig and see if the wires are the same. Thanx for the info.
Old 02-27-2009, 11:07 PM
On the same not I just got a set also what wiring do I have to do to get them to work on a 2001? my stock wiring only has 3 wires
