coolant filter - Ford Powerstroke Diesel Forum
Old 01-01-2009, 06:42 AM
coolant filter
Hi im new here and was wondering whether or not it would be worth putting a coolant filtration system on my truck. Ive noticed that there is a lot of residue in my coolant reservoir. Where is a good place to buy one? I have a 03 F250 with a 6.0. Thanks alot.
Old 01-01-2009, 06:52 AM
Dieselsite from what I've researched. I'm just not sold on those $20 cheapie valves. I'd use a 304 or 316 stainless Apollo ball valve.
Old 01-01-2009, 07:03 AM
thanks, found the kit and it looks pretty easy to install.
Old 01-01-2009, 01:07 PM
Have the dieselsite kit on my truck. just changed the filter on Monday. Ball vavles worked perfectly.
Old 01-01-2009, 01:12 PM
I installed one in my 7.3 it only took a few hours. i haven't had it on there long enough to see if it did any thing but so far I'm glad i put it on. all the bigger diesels have them so it can't hurt but then again its one more filter you got to buy
Old 01-01-2009, 01:21 PM
ya it is one more filter that's true. I'm just gonna buy them from dieselsite. It's bypass also so if that one get's 'clogged up' then it will still flow coolant. Pretty sweet.
Old 01-03-2009, 08:03 AM
thanks guys think ill buy one
Old 01-03-2009, 08:17 AM
cj41foleyisathief
Yes Dieselsite has them or you can diy one from napa for 50.00 total. I just mounted the filter off the alt so it only lets out a little coolant when I replace the filters.
Old 01-03-2009, 09:00 AM
what are the part numbers that you bought for the diy from napa. Also would you know what to buy for diy oil bypass filter
Old 01-03-2009, 09:08 AM
cj41foleyisathief
Go to Wix filters - oil filters, biodiesel filters, air filters, and fuel filters from FleetFilter! and pick out a filter and base. Order it or go to napa and get it.
