HID install problems - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-31-2008, 10:43 AM Thread Starter
k2davis1's Avatar
Kinda confused on how to install my HID kit. The bulbs hook to the ballast via 2 connectors and then there is another connector that plugs into the ballast with a blue and black wire that are bare on the other end. Do i just stick those into the stock headlight plug for power? I found low, hi, and ground and I plugged everything in and when i turn my fogs on the hi beam indicator comes on dimly. My lows work so im thinkin everything is good but why is the HI indicator comming on the dash when fogs are goin. HELP
Do I need to run a separate ground? Thought the kit would of came with a nice connector that would plug into the stock harness and i'd be done instead I got a harness with 2 prongs and bad directions.
Maybe once I put my HID fogs in it will fix it.....
2008 F-350 Crew Lariat FX4
6" RCX lift W/37" Falkan A/T
24" Fuel Hostage
5" Flo-Pro Straight
H&S Mini Maxx
S&B CAI
k2davis1 is offline
post #2 of 17 Old 12-31-2008, 10:47 AM
Raul@Stealth Automotive's Avatar
the 2 lil prongs go into you OEM harness...
Most H13 kits dont come with the connectors to plug into your OEM harness..
is the kit a low beam only kit? or does it have high beams as well?
Raul@Stealth Automotive is offline
post #3 of 17 Old 12-31-2008, 10:49 AM Thread Starter
k2davis1's Avatar
As far as i know its low only, I would be able to tell if it was both right?
24" Fuel Hostage
5" Flo-Pro Straight
H&S Mini Maxx
S&B CAI
k2davis1 is offline
post #4 of 17 Old 12-31-2008, 10:50 AM
if it was both your bulb would have 2 bulbs in it...
i can try and guide you through the install but a picture of what you got would be better....
where did you get the kit? did you get full digital ballasts?
post #5 of 17 Old 12-31-2008, 10:53 AM Thread Starter
k2davis1's Avatar
Got the kit from Intense HID. Ill take a pic tomorw when i get a chance, I have the prongs in the right spots i think, one in the center(ground) and one in the right(low beam).
BTW I just got my z-plate its sweet, thanks again
24" Fuel Hostage
5" Flo-Pro Straight
H&S Mini Maxx
S&B CAI
k2davis1 is offline
post #6 of 17 Old 12-31-2008, 11:06 AM
yah thats exactly where is should be.... not sure why the high beam indicator goes on.. thats odd...
post #7 of 17 Old 01-01-2009, 01:18 PM Thread Starter
k2davis1's Avatar
heres some pics of the install:
ballast and harness
cut stock harness and added connectors
ballast mount
6000k Bulbs, they look more blue in person
24" Fuel Hostage
5" Flo-Pro Straight
H&S Mini Maxx
S&B CAI
k2davis1 is offline
post #8 of 17 Old 01-01-2009, 03:31 PM
nice install... but i wouldnt of cut your stock OEM harness.... i would of purchased a H13 male plug and cut the HID kit and spliced it into the plug so you could just plug it right in...
but thats just me...
they look great BTW
-Raul
post #9 of 17 Old 01-01-2009, 04:38 PM
CCSBD's Avatar
Looks good I want to do this also sometime
***SOLD***
'04 CrewCab ShortBed 6.0 4x4
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
Sinister Coolant Filter
Recon Smoked Cab Lights
SCT X3 Tuned by Innovative
4" MBRP SS Turbo Back Exhaust
ISSPRO EV pyro, trans, boost guages
CCSBD is offline
post #10 of 17 Old 01-01-2009, 04:46 PM
utlonghorns416's Avatar
I have a kit as well how much is your kit stealth. My kit came and broke and I dought my bulbs are ever coming. 2006 350
utlonghorns416 is offline
