Tq Spec Question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-30-2008, 06:17 AM Thread Starter
Tq Spec Question
I'm rotating my tires for the first time this weekend and was wondering what the Tq Specs are for the lugnuts on my 06 F250 4x4. Thanks for your help.
bjl584 is offline
post #2 of 7 Old 12-30-2008, 06:23 AM
mrgrimm's Avatar
Quoted: 6 Post(s)
150 lb-ft would probably be safe(specs for 02), then re-tourqe after just a couple hundred miles.
mrgrimm is offline
post #3 of 7 Old 12-30-2008, 06:24 AM
mrgrimm's Avatar
Quoted: 6 Post(s)
...It's a bump anyways, 06 guys set him straight!
mrgrimm is offline
post #4 of 7 Old 12-30-2008, 06:37 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
That sounds about right. I never actually torque mine. Just tighten them with my air impact. And then give em another bump with it in about 100mi. But they have never loosened up on me
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 7 Old 12-30-2008, 08:38 AM
I'd NEVER use an impact wrench to final tighten the nuts. The torque produced by an impact is extremely unpredictable. Too loose and your lug nuts fall off. Too tight and you'll stretch the lug studs and the lug nuts will fall off. If you have torque sticks they work ok. Lazy garage mechanics get away with it, but good ones will final torque with a torque wrench.
Use a torque wrench. We're talking about a work truck with serious loads and serious consequences. Someone with the right FSM please provide him a good torque number.
Truck owners get anal retentive about a lot of things, many of them hardly matter in the end. But this is one that is seriously important enough to adhere to.
Dave
dgeesaman is offline
post #6 of 7 Old 12-30-2008, 08:54 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
it is written on the lug nuts, 150 lbs is the torque
ITS STOCK
SCUFFY828 is offline
post #7 of 7 Old 12-30-2008, 09:52 AM
i have a 2004 f350 diesel and the torque specs on my wheels are 165 lbs..clay
CLAY/04 is offline
