smoke switch threw code
Just did the smoke switch, number one not much smoke and number two threw a code right away, does anyone have or know where to get a listing of all the codes ??
code that came up was B0115 can't seem to find what it is though.?
B0115 Passenger-Side Air Bag Circuit Malfunction
http://http://www.4wheelnoffroad.com/codes.html Maybe you got too much smoke in the door?? j/kDoesnt make much sense does it, unless it was just a coincidence? |
b code isnt with the engine, if check engine light is on then you have to have a code
every time i turn the switch on the check engine light comes on ... and i seem to keep getting random B codes from it, ill try it again in a little bit and see what code it gives me this time.
Just flipped the switch two more times brought back two different codes, this time P codes, P0005 and P0015 ... every time is a dif code.
P0005 - Fuel Shutoff Valve "A" Control Circuit/Open
P0015 - "B" Camshaft Position - Timing Over - Retarded Bank 1 Why am i getting these codes for the smoke switch ?? |
ditch the switch.....................
If you want smoke, floor it. If you want more smoke, ask eric to write you a smoke tune. His tunes are very strong for the relatively small amount of smoke they emit.
