Changing Power steering fluid
The manual recommends mercon ATF, in my 06 superduty. Would anyone suggest making a move to a synthetic for the power steering fluid? What sythetic would be compatable with the mercon atf?
In all my years I have never changed the PS fluid in any vehicle. I just looked at it like a pump (which they are). What's the point?
What's the point?
Maybe it's a waste but I read somewhere, I think it was an aftermarket service manual, that it was not a bad idea to change it. I just change it like all other fluids, even brake fluid. Maybe it's a total waste of time and money but I would rather over maintain than under maintain. There are moving parts in these things right? I thought that changing these fluids would get rid of any possible contaminants, ie., moisture, wear particles, etc. |
Brake fluid yes, just never heard of PS fluid before.
i agree, plus his truck is only 2 years old i dont think it really needs to be changed but then again its not my truck
There is a TSB that directs the shop to install a filter on the power steering fluid if you have specific hydroboost problems. So it seems that there are occasional issues with power steering fluid quality. There is even an aftermarket filter you can install (very much like the one Ford would put on temporarily for the TSB).
That being said, I sure haven't read about very many problems with fluid quality - maybe one or two in a couple of years across multiple forums. The power steering fluid does not absorb water like brake fluid and does not get dirty and use up the additives like a lubricating oil. |
Here is the TSB (07-11-10):
ISSUE: Some 1999-2008 F-Super Duty, 2000-2005 Excursion, and 1997-2007 E-Series vehicles equipped with Hyrdo-BoostŪ brake booster system may exhibit a brake pedal kickback and/or grabbing condition when applying the brakes. This may be caused by contamination within the power steering system. ACTION: Filter the power steering fluid by installing a temporary filter in the power steering system. Refer to the Service Procedure below. SERVICE PROCEDURE Verify that the line from the pump and the line to the gear at the Hydro-BoostŪ are in their correct orientation (and not crossed). The passenger side goes to the pump, the driver side goes to the gear. Attach a pinch-off clamp to the lower power steering hose approximately 6" (15 cm) from the lower port of the power steering cooler to keep fluid from emptying out of the system when the hose is disconnected. Disconnect the power steering hose from the lower port on the cooler. Cap the cooler port to minimize fluid leakage and immediately install the temporary filter in line with the power steering hose using hose clamps to retain the filter (the filter needs to go in the low pressure line that goes from gear to cooler to reservoir, where it would be most accessible). Attach the other end of the filter to the cooler using the clamps provided. Remove the pinch-off clamp from the power steering hose. FILTERING PROCEDURE CAUTION: BE SURE THAT THE PARKING BRAKE IS APPLIED DURING THE FOLLOWING STEPS 1-7. Check power steering fluid level before starting the vehicle. Start the vehicle and allow it to idle for approximately 15 seconds. NOTE: DO NOT HOLD THE STEERING AT LOCK FOR MORE THAN 5 SECONDS. Turn steering wheel lock-to-lock 10 times. Pump service brake pedal hard to floor 25 times. Turn steering wheel lock-to-lock 5 times. Remove the filter and reconnect the power steering line to the cooler. Discard the filter. Fill the power steering system. Refer to Workshop Manual (WSM), Section 211-00 Power Steering System Filling. With the engine at idle, gradually apply the brake pedal until fully applied. If the brake pedal kickback persists, replace the Hydro-BoostŪ brake booster. Refer to WSM, Section 206-07. PART NUMBER PART NAME XC3Z-7B155-BA Power Steering Fluid Filter Asy 5C7Z-2005-B Hydro-BoostŪ Asy - 1999-2004 F-Super Duty / 2000-2005 Excursion 6C3Z-2005-AA Hydro-BoostŪ Asy - 2005-2007 F-Super Duty 7C3Z-2005-AA Hydro-BoostŪ Asy - 2008 F-Super Duty F7UZ-2005-AA Hydro-BoostŪ Asy - 1997-1998 E-Series XC2Z-2005-AA Hydro-BoostŪ Asy - 1999-2001 E-Series 6C2Z-2005-AB Hydro-BoostŪ Asy - 2002-2007 E-Seres |
Interesting stuff. Well I'm not having any trouble and maybe changing the fluid is not needed, but what's a quart of fluid cost, $6.00? I just remember having noise and dead spots in the power steering of other vehicles I've had when getting some miles/age on them. When I saw this maint. recommendation in the aftermarket service manual I thought it might be a good idea. My last truck, a Dodge, started acting funny around 60,000 miles. A local auto parts shop recommended changing out the fluid to a synthetic power steering fluid and conditioner he had. The power steering acted like new when I serviced it with the product he recommended. So, seemed like it couldn't hurt to stay ahead of the game with a simple fluid change, maybe over to synthetic since most of the units start by making noise and whining in the cold weather.
A filter huh? I like filters
By the way, does anybody have a synthetic recommendation to use in place of the mercon atf or should I just stay with the oem mercon atf?
