Block Heater ? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-22-2008, 06:27 AM Thread Starter
agamache's Avatar
Block Heater ?
How cold does it get before you plug them in and how long can you leave them pluged it. It is 9 degrees here
SERENITY
GOD grant me the SERENITY to ACCEPT
the things I cannot change,Courage to
change the things I can and the
WISDOM to know the differance
2004 F250 EXT CAB 4X4
EDGE JUICE WITH ADITTUDE
MBRP 4" TURBO BACK EXHAUST
KITTY FELL OFF
COOLANT FILTRATION SYSTEM
agamache is offline
post #2 of 10 Old 12-22-2008, 06:31 AM
scheidt27's Avatar
I usually plug mine in below 20*. U can leave it plugged in as long as you want, it justs costs more is all. 4hr minumum of being plugged in for the block heater to do you any good as well.
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #3 of 10 Old 12-22-2008, 07:49 AM
pwrstroke6john's Avatar
Well My 550 wouldnt start yesterday and it was 8 so i would say above that.
2005 F350 crew cab short box
6 inch pro comp lift
35x12.50-20 Nitto Trail Grapplers
Moto Metal Rims
5 IN MBRP Turbo Back Straight Pipe - 6 IN Tip
AFE Cold Air Intake
SCT Tuner
Coolant Filter
EGR Delete
15% Window Tint
6000k HIDS
Bushwacker Flares
Buckstop Front Bumper
Custom Rear Bumper
Weatherguard Box
pwrstroke6john is offline
post #4 of 10 Old 12-22-2008, 07:56 AM
sikktruk01's Avatar
usually anything below freezing I use my block heater.
I just bought a programmable timer @ walmart.
works good, just set it to come on a few hours before you head out. I didn't like leaving it plugged in all night.
platinum edition F250 crewcab, 7.3 powerstroke,8 inch fabtech, 37x13.5x20 kumho m/t, 20x10 A/R teflon thug,6 FOX shocks and stabilizer, stainless toolbox, line-x, 4 inch exhaust, AEM intake, wicked wheel, Dp-tuner, Autometer C2 Gauges, kenwood in dash TV/DVD with navigation, sirius, bluetooth and back up camera, infinity and JL audio speakers, PPI amp, 08 diff cover, braided brake lines, onboard air w/ train horns,E-Z down tailgate
sikktruk01 is offline
post #5 of 10 Old 12-22-2008, 07:59 AM
jblagg's Avatar
yep I did the same thing.
I set it to come on at 4 a.m. and when I leave at 6 its s always warm enough
03 F350 PSD
7.3 AUTO
EXT. CAB,
LWB, FX4
jblagg is offline
post #6 of 10 Old 12-22-2008, 08:00 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
There is no minimum time for leaving it plugged in. mines on a timer for 2 hours and heats my water to around 110 when its about 30 outside. If its colder than that, i still see water temps of 90 upon startup after 2 hours heating. If you only leave it on 1 hours you will still see it starts easier but 2 hours is better. You can leae it plugged in over night but your electric bill will reflect this.
Theres no magic number to start plugging it in at, its kinda pointless at 40* and 30* you will see your heater warms faster but the truck probably doesn't have a hard time starting at 30 so as stated, 20 degrees you will see the benifits of the heater when you start it.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #7 of 10 Old 12-22-2008, 08:02 AM Thread Starter
agamache's Avatar
never thought of the programable timer. I will have to give it a try. Thanks for all the info
SERENITY
KITTY FELL OFF
agamache is offline
post #8 of 10 Old 12-22-2008, 08:06 AM Thread Starter
agamache's Avatar
If I start plugging it lets say below 20* and i go to work and am there for 12hours and it gets below 10* will i any trouble starting it do to the fact i have been plugging it when it get this cold. I dont have a way to plug it in @ work
SERENITY
KITTY FELL OFF
agamache is offline
post #9 of 10 Old 12-22-2008, 08:07 AM
scheidt27's Avatar
mine only has trouble on the first cold soak start of the day, aka the first morning start. In my experiences you would be fine. Mine will sit all day and pop right off after sitting for 8-10 hrs.
2002 F250
All Supporting Mods
post #10 of 10 Old 12-22-2008, 08:25 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Plug it in when you can....thats all you can do. Most people can't plug it in at work.
