EGR delete - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-21-2008, 08:29 AM Thread Starter
EGR delete
I am new to diesels only had about a year but read on here things that can be done. Just wondering what the purpose of an egr delete is and is it worth doing?
Stroking the oilfield is offline
post #2 of 11 Old 12-21-2008, 08:41 AM
psd
if you have a 6.0 power stroke. I think It's the best thing you can do for your truck. it keeps the coolant from boiling over your over flow tank and as well for your HG.your motor will run cooler.
if you want to check one out we have three types.
here at Welcome to Outlaw Diesel :: Home we also have custom tunes for you.
outlawdiesel is offline
post #3 of 11 Old 12-21-2008, 04:56 PM
Patrick's Avatar
It appears that you have a stock truck, so deleting the EGR will do nothing for you. Plus to do this you will need custom tuning to remove it from your trucks computer. If your truck is puking a little when its worked hard, remove a little coolant from the over flow bottle. Your max fluid level should be moved to the minimum line. If you plan on tuning this truck I recommend calling Innovative Diesel and getting a custom SCT Xcal3 with the EGR turned off. Then you can remove the up pipe from the passenger side and cut a thin metal disc to plug the EGR pass thru. A lot more important that the EGR delete will be head studs if your gonna push her hard.
Legendary
Patrick is offline
post #4 of 11 Old 12-23-2008, 12:15 PM
GGOODMAN's Avatar
unplug it if you dont get a CEL you can remove the valve and cooler. If your in waranty dont touch it till your out. Unless you get a mod frienly dealer.
04' F250
4x4 cc Lariat
50k
4" lift 315's
Zoodad mod
Lead foot Disease (pump prices have nearly cured me)
GGOODMAN is offline
post #5 of 11 Old 12-23-2008, 12:18 PM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Will I fail my emissions test if I do this delete?
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #6 of 11 Old 12-23-2008, 12:41 PM
<-Day Of Fail now SOLD
POWERED SPARKLESS's Avatar
No
As of now we don't an emissions test. We have emission standards and emissions inspecion. All they do is look to see if you CAT is still there and might look to see if your EGR valve is installed. I don't know how your part of CO is but most inspection stations could care less, and if you do, keep the CAT round for that once a year inspection.
Tyler T
Sold 2 April 2011
To some lucky SOB
2004 6.0 CC FX4 Lariat
It had all the right things missing or added
Originally Posted by DunesRunner08 View Post
IF YOU DO NOT STAND BEHIND OUR TROOPS....FEEL FREE TO STAND IN FRONT OF THEM!!!!!
POWERED SPARKLESS is offline
post #7 of 11 Old 12-23-2008, 12:46 PM
If you want one of the most complete EGR system delete kit most everyone will agree this is one of the best kits out there.
First Coast Diesel Performance
Tyler T
Sold 2 April 2011
To some lucky SOB
post #8 of 11 Old 12-23-2008, 12:56 PM
2006PSDSD's Avatar
Quoted: 24 Post(s)
Originally Posted by POWERED SPARKLESS View Post
No
Yeah they're usually just a bunch of pot head kids doing the e-tests here. I haven't gotten to do a diesel emission test yet, just gassers. I do have the cat, and will need to make a nice flanged delete pipe and then add some flanges to my cat so that I can make a quick swap
Where are you from, just curious what kind of laws you have?
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #9 of 11 Old 12-23-2008, 01:04 PM
Orginal from Uah, but now in North Carolina. Out here they could care less what is on a diesel. Most of the inspection stations don't even know that some diesels have EGR, and CAT's.
I still have my CAT wrapped and stashed away just in cast one day I might need it. I would have get the pipes changed because I have 5" system and the CAT is 3.5" and the conetions are completely diffrent. But then again I don't ever plan on needing it again.
Tyler T
Sold 2 April 2011
To some lucky SOB
post #10 of 11 Old 12-23-2008, 01:15 PM
2006PSDSD's Avatar
Quoted: 24 Post(s)
So your saying that most test centers just do a visual inspection and then test for opacity and that's it? Colorado emissions are kinda strict, so I may get busted
I still have some pipe left over from the exhaust kit that I installed. I was going to take a portion of that pipe and weld it to my cat and put flanges on it so that the swap isn't a PITA.
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
