New PCM flash... TSB 7-18-4
was checking TSB's tonight... Looks like the latest and greatest flash is TSB 7-18-4:
Engine - Controls - MIL ON/DTC P0470 in Extreme Cold TSB 07-18-4 09/17/07 6.0L - INTERMITTENT MIL ON AND/OR INTERMITTENT DTC P0470 - TEMPERATURES BELOW FREEZING FORD: 2006-2007 F-Super Duty ISSUE Some 2006-2007 F-Super Duty vehicles equipped with a 6.0L diesel engine may exhibit a intermittent malfunction indicator lamp (MIL) light on and/or intermittent diagnostic trouble code (DTC) P0470 only in conditions where ambient temperatures are below freezing on start up. ACTION Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 50.10 and higher. This new calibration is not included in the VCM 2007.7 DVD. Calibration files may also be obtained at the website. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. OPERATION DESCRIPTION TIME 071804A 2006-2007 F-Super Duty 0.7 Hr. 6.0L: Check For DTCs And Reprogram The PCM (Do Not Use With 12650D) What do you guys think? I had my supposedly reflashed with TSB 7-5-4 this past summer. |
FYI - TSB 7-5-4 was superceded by TSB 08-26-3.
In this new TSB, it states: If the FICM contains one of the following files then it has already had the Inductive Heat calibration installed: ARZ2AH00 ARZ2AL00 ARZ2AL01 Last edited by bismic; 12-15-2008 at 06:41 PM. |
huh. so the last flash/TSB to flash is what?
I got this today after my truck got the SES light on my way to work. It was a nice warm -5 this morning.
I haven't noticed much difference yet, though I haven't had a start after a cold soak nor a SES light since. |
Previous post was just an FYI for reference on the Inductive Heat Flash and how to confirm that you have it (since you stated "my supposedly reflashed with TSB 7-5-4 this past summer").
The TSB 7-18-4 (Issued September 07) just instructs to program the PCM to the latest calibration version to fix (DTC) P0470 and MIL on in cold weather. I believe you are correct in saying that if the service department applied TSB 7-18-4, it would mean that the latest PCM calibration was applied at that time. TSB 7-5-4 was the TSB to apply the FICM re-programming to the Inductive Heat flash. This has now been supeceded to the one I mentioned (TSB 08-26-3) which instructs to verify latest FICM program. TSB 08-26-3 6.0L DIESEL - DRIVEABILITY - NO START, HARD START, RUNS ROUGH - FUEL INJECTION CONTROL MODULE DIAGNOSIS https://www.motorcraftservice.com/pu...sb08-26-03.htm Last edited by bismic; 12-15-2008 at 06:50 PM. |
so for us common folks the latest PCM flash would be... ARZ2AL01 ?
