Dry Snow and cows = plugged filter
Should I replace it or will it be ok when it defrosts and drys?
how big is your zoodad hole how did it get that much in there
I must be an idiot...how do the cows fit in to this equation?
How did that happen, zoodad? That's one reason I was hesitant about doing one on my truck......
I have no zoodad hole. Didn't do that for this very reason. And it still happened.
There was even more caked on to it when I removed it. Even the small hose at the top was plugged of snow. Powdery snow, and wind makes it fly every where, even when only a few inches deep. Just really surprizing to see the check filter warning.On a side note. Twas -20 this morning and I didn't plug it in had a |
It's cold and they didn't want to follow the tractor to shelter. So they needed some help moving.
Should I get a replacement filter, or will this one be ok, when it dries?
Should this still happen, or did I encounter the perfect conditions? |
Those are always good times lol
You probably encountered perfect conditions for this to happen. |
Let it dry out then check the filter minder. If it says it's o.k. then chase some more cows and save your money.
