Techs: Diff cover sealant of choice? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-13-2008, 03:42 PM Thread Starter
JBakerFX4's Avatar
I was reading the FSM and they are calling for a "clear silicone sealant" part number TA-32 for diff cover sealant. When I popped it the original time it had GRAY sealant on it. I was on motorcraft's website and they have the TA-32... and then I found TA-29, which is a HD gray sealant that is for axle covers and such also. Sounds like from the factory it came with TA-29, but the FSM is calling for TA-32. What do you guys at the dealers prefer?
'09 Tacoma CC/SB, TRD Off-road.
NRA member
One Nation Under GOD!
JBakerFX4 is offline
post #2 of 8 Old 12-13-2008, 04:12 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
Use the GRAY goop as it's affectionatly called. You won't have ANY leak problems like you might with that clear crap. It's tough as hell to remove, but it's the SH!T. PERIOD!
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #3 of 8 Old 12-13-2008, 04:22 PM
03dieselman's Avatar
Yeah don't use the clear, the black rtv is what I have used on all my trucks and suv's. It has excellent sealing and adhesion properties. I'm not a tech by any means but I hope that still helps.
06' F250, 6.0L, Xl, 4x4, 3:73 Ls 4" Turbo Back,
12' F150, 4X4, 3:55 E Locker, Xlt, Super Cab, Ecoboost, Sct Tunes
94' Jeep ZJ, 4" Rough Country, 33's, And A Bunch Of Broken Parts.
10' Polaris Sportsman 850 Xp!
03' 6.0L Sold
96' 7.3L Sold
87' 6.9L Sold
03dieselman is offline
post #4 of 8 Old 12-13-2008, 04:49 PM
bottledgt's Avatar
sealant is sealant...if you do it right it wont leak...i prefer black myself, but anything will work if tis clean
bottledgt is offline
post #5 of 8 Old 12-13-2008, 08:27 PM Thread Starter
JBakerFX4's Avatar
10-4. Gray Goop. should be ford # TA-29. Yes, it is hard to remove... as a temporary rtv i used the permatex blk. but I prefer to use the gray stuff that came from the factory.... that was a job to remove!!!
NRA member
post #6 of 8 Old 12-14-2008, 09:03 AM
GAS
GAS's Avatar
It's black, very tacky and is called "The Right Stuff"
Works great for all kinds of stuff, pan gasket substitute, diff covers, water pumps, you name it!
Paticulary it sticks like crazy, even to areas you might have missd some oil.
Micha, Pleasant Grove, Utah
99 F350 Crew cab long bed, Tymar intake(The real deal)
Zoodad, 4 inch exhaust, Dipricol gauges, WW,
gutted turbo pedestal and ebpv deleted big exhaust outlet, ccv delete
GAS is offline
post #7 of 8 Old 12-14-2008, 09:12 AM
Black RTV for Napa here.
TANK'S 250 is offline
post #8 of 8 Old 12-14-2008, 10:01 AM
I like the Ultra Grey from Permatex. JJ
04 F-550 CC 6.0 4x4 cab n chassis 4.88 XLT 193K
Money maker with utility bed.
97 F-350 CC 7.3 ZF-5 4x4 4.10 324K
Moves my stuff around.
Hardline is offline
