Coolant drain/refill problem - Ford Powerstroke Diesel Forum
post #1 of 22 Old 12-06-2008, 12:19 PM Thread Starter
LiftedBlackHD's Avatar
I'm in the middle of draining and refilling my truck with fresh coolant. I have drained twice and flushed with distilled water to try and clean it out. The issue I'm having is that when I refill I am only getting about 4 gallons in before its full. I believe the system capacity is about 7 gallons. I pulled the freeze plug on the drivers side but not the passenger side because of the location. If I'm only refilling with 4 gallons there is no way I will get a good 50/50 mix.
2004 (12/03 build) F250 Super-Cab Long-Bed PSD 4x4
SCT tuned by DJ
Innovative 05-07 Intake Elbow
Dieselsite Coolant Filtration System
8" Icon lift
Fab-Tech dual steering stabilizer Kit
20" KMC Rockstars (Black)
38x15.50 Toyo Open Country's M/T's
Zoodad mod, CCV mod, High-idle mod
Straight Piped, Outlook monitor, Recon Led's
LiftedBlackHD is offline
post #2 of 22 Old 12-06-2008, 12:44 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Drain and refill your only going to get about 5 gallons tops back in. Fire it up, let it warm up and open the thermostat. Go drive it to make sure its not going to burp then check it again.
post #3 of 22 Old 12-06-2008, 01:03 PM Thread Starter
Thanks! I've done that twice now and like I said I'm only getting about 4 gallons back in.
SCT tuned by DJ
8" Icon lift
post #4 of 22 Old 12-06-2008, 04:28 PM
If you are getting 4 gallons out each time, I would recommend the fill and flush to be done 5 times. After the fifth time, you should only have a quart or so of the old stuff still left in.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #5 of 22 Old 12-06-2008, 08:49 PM Thread Starter
Holy crap, this turned into quite a project! I drained the coolant at about 9am. Poured in some cooling system cleaner along with about 4 gallons of distilled water and drove for about 30 min. On the 2nd drain I pulled the drivers side freeze plug to drain more water. I repeated this about 4 to 5 times. I was frustrated with the fact that I was only refilling with about 4 gallons of distilled water each time.
On the 3rd trip I stopped by Napa and picked up a new 4070 coolant filter.
On the 4th trip I stopped by the local "adult" store and picked up some special dice that I am going to be using in about 10 minutes.
I drained and refilled with water 5 times. On the last trip I decided that I was going to pull the freeze plug on the pass side as well so that I could get a true drain.
What a mistake! After some investigation I discovered that the only way to pull the pass plug was to remove the hot wire to the starter. So no prob I pulled that wire after disconnecting the batteries and removed the plug. Well when I removed the plug it fell. I figured what the hell, I'll just grab it later...I proceeded to pull the rad hose and drivers freeze plug.
Now I'm ready to refill, obviously I need to replace the hose and the plugs. I replace drivers side plug and rad hose. When i tried to replace the pass side plug I couldnt find it. The SOB was lost somewhere between the starter and engine block. I tried for about 2 hours to find it. I used my hand, a screwdriver, a magnet, etc... I just couldnt get it. Finally by this time it's getting dark.
I'm trying to hold a flash light, contort my body into strange positions, twist, turn, and flex and finally I had to pull the starter. I pulled the starter, and low and behold the plug was there! I put it back in and put everything back where it belonged.
A simple change of coolant turned into an full day long project. These trucks are bad ***, but sometimes I wish for the old days of my 65 mustang where everything was quick and simple. Oh well, a day spent with my stroke is a good day indeed!
SCT tuned by DJ
8" Icon lift
post #6 of 22 Old 12-07-2008, 07:42 AM
Jon
Guest
Posts: n/a
Quoted: Post(s)
I dont understand why your going to such lengths to get every drop of coolant out? It does not make any sense to me? Drain the coolant and refill it. If your not happy with that you could have paid a shop to hook it up to the coolant flush machine and been done in 20 mins. Why on earth would you start pulling freeze plugs out?
post #7 of 22 Old 12-07-2008, 04:06 PM Thread Starter
When you change you engine oil do you only drain half of it?
SCT tuned by DJ
8" Icon lift
post #8 of 22 Old 12-08-2008, 06:34 AM
ADMIN AND TECH
SCUFFY828's Avatar
THERE IS ABSOLUTLY NO REASON TO PULL FREEZE PLUGS , THATS IS GOING WAY TO FAR
ITS STOCK
SCUFFY828 is offline
post #9 of 22 Old 12-08-2008, 06:38 AM
ADMIN AND TECH
SCUFFY828's Avatar
totally different , but if you want to get technical , no you dont drain all the oil out , there is still at least 3 quarts in the oil rails inside the engine , high pressure pump is still full and the valley of the engine below the oil cooler so no , you dont get it all out
doing a drain and refill on a 6.0 for one doesnt even need to be done till at least 80,000 miles , it has long life coolant with all the additives for that engine in it , unless , there is a problem, such as oil or fuel in the coolant , there is no purpose to got this far
ITS STOCK
post #10 of 22 Old 12-08-2008, 06:44 AM
<-Day Of Fail now SOLD
POWERED SPARKLESS's Avatar
-Derail- Scott I read a while back that when doing a coolant flush one of the best detergants is cascade?? When I ever get a around to flushing my system how much should I use? And how can I know for sure that it all out?
Tyler T
Sold 2 April 2011
To some lucky SOB
2004 6.0 CC FX4 Lariat
It had all the right things missing or added
Originally Posted by DunesRunner08 View Post
IF YOU DO NOT STAND BEHIND OUR TROOPS....FEEL FREE TO STAND IN FRONT OF THEM!!!!!
POWERED SPARKLESS is offline
