Bolt Pattern 2005 F350 4x4 SRW
Just want to confirm that the bolt pattern for a 2005 F350 4x4 SWR is 8x170mm.
Thanks, John |
Correct....99+ SRW SDs are 8x170mm
Thanks, I found a great deal on a set of new wheels and I want to jump on it, what is the smallest diameter wheel that will fit?
18's and up will fit for sure....some 17's do but not all.
Thanks for the info! Florida fireman here.
Just ordered the new wheels, 4wheel parts wholesale had them for 75% off, got the set for $372.00. Weld Racing 18x10.
suprised they had anything left
Me too, they have lots of wheels on clearance for 75% off.
All Superdutys 99-08 that are singe rear wheel models use the 8x170mm bolt pattern.
Old body style(OBS) is 8x6.5 The 05-08's have larger brakes so the backspacing is different than the 99-04's. In 05 ...engineers to upsized brake rotors by 5 percent, to 347 mm in front and 340 mm in rear. Other improvements include larger calipers for both the F-250 and F-350. The front calipers have twin 60 mm pistons - up 11 percent from 2004 - for better braking feel. Rear calipers have twin 48 mm calipers on F-250 and twin 54 mm pistons on F-350 dual-rear-wheel models. BACK SPACING 99-04......4" 05-07.......18"and 20"(from the factory) have 5.80" BS, and the 17" have 5.50" 00-04s came with 16s (unless it was a Harley Edition, they had 18s)...they don't clear the calipers on the 05-08s. A 04 HD wheel would fit on a 05-08 since they were 18s, but they had less backspacing so they sit further out of the wheel wells on 05-08s. 05-08s fit on the 99-04, just rub on the leaf springs and sit further under the truck than they do on the 05-08. Offset is the location of the wheel mounting surface in relation to the true center of the wheel......normally in mm. Negative does move it inward. So.... A 20x10 wheel with a 4.5" BackSpace will have approx -24 or -25mm offset. A 20x12 wheel with a 4.5" BackSpace will have approx -51mm offset. FYI, 25.4mm=1" |
shouldnt you be working on Matts truck? lol
