Anyone fix "the clunk"
When going over bumps I can feel a solid clunk right under my feet like someone is under the truck with a hammer. Been underneath many times lookin for the culprit but nothing is loose. Does anyone have a similar problem or maybe a fix?
Could be ball joints, spring bushings, loose or worn out shock.....
Just put new shocks on. Need to check ball joints I guess
Re-torque the trac bar mounts and bar ends.
There was a body mount right under my feet in the excursion and it made a thunk on bumps and under heavy braking.
The clunking sound that I had in the past, turned out to be the front (driverside) bushing on the swaybar. It had came out of the bracket holder. Popped it back in, and has been fine since.
yeah this clunk it making me go crazy..happens when i back in or pull out of my drive ..i have 4 link setup and thought it was radius arms when it was stock but it still happens..i guess im glad im not the only one with this problem.
The only clunk I have had is the track bar. It was easy to find because I could cause the clunk by turning the steering wheel back and forth.
Take your sway bar completely off and see if the clunk is still there. Then you'll be able to narrow it down.
ahhh the infamous clunk. Fix it, it comes back, fix it , it comes back. So much fun.
