Hello folks, new to Powerstroke family, I am looking to purchase a 2006 F550 crew with 11 ft service body.
2006 F550 service truck with 122 km (76 miles),5210 hrs on meter, it has had some engine work done but not all i think should be done.
The seller has provided work order for the following : june 2012 @ 102 km (64 miles), high pressure oil pump, fuel pressure regulator, EGR delete, & oil cooler kit,
july 2012, mileage unknown : vacuum pump & reservoir, turbo vane actuator, EGR sensor, & AC repaired
May 2013 @ 108 km (67 miles): turbo vane actuator, alternator,& 8 injectors.
The truck is a tire service vehicle & may be cause of some of the engine repairs required.
Any thoughts on this vehicle? bulletproofing items to address? I know first off is coolant filter kit, then 1 month, 3 month & coolant flush. Scan 2 or Edge monitor. No mention of blue spring or FICM in the repairs. Required ?
THX in advance.
THX in advance.
