Leave it running or shut it off? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 12-02-2008, 12:40 PM Thread Starter
I've always noticed how some people with diesels will leave their truck running rather than cutting it off if they are going to be parked for a while. They claim that it takes more fuel to start it up than it does to leave it running for a little while. I am just curious if this is true.
Whats the theory behind this?
2005 F-250, Sct x3 with Innovative tunes, Edge Insight for gauges. Straight pipe. K&N intake. ARP headstuds. EGR delete.
400exrider is offline
post #2 of 29 Old 12-02-2008, 12:42 PM
duct tape & zip ties
bigcountrysg's Avatar
On a big rig it is true. On our trucks really doesn't matter. As a warm engine starts relatively easy. Where a cold engine starts hard and will use more fuel to start.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 29 Old 12-02-2008, 12:46 PM
fordpwrstroke7's Avatar
Gotta be careful with your idle time though if you still have your EGR...it will contribute to clogging it up.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #4 of 29 Old 12-02-2008, 12:47 PM
Unapologetically American
2006PSDSD's Avatar
Quoted: 29 Post(s)
Feedback Score: 4 reviews
Took the words out of my mouth
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #5 of 29 Old 12-02-2008, 12:59 PM
DIESEL POWERED ROCKET's Avatar
You don't want to turn off your truck after a hard run because it will roast the oil trapped in the turbo bearings. The result of doing this will build up carbon and will quickly kill the bearings.
I see allot of people with turbo timers but this too will waste fuel if you dont pick the right amount of shutdown time.
I use a turbo temp monitor that will only keep the truck running long enough to reach your set point and then it will shut off. I have noticed in my truck that I will reach my shutdown temp setting just cruising in town for a city block or two at 25 or 30 MPH.
04 F350 Extended Cab 6.0
2.5" Leveling Kit
SCTX3 Tunes by Eric @ IDP
Banks Ram Air Intake / CFM + Elbow / Fuel REG Mod
Banks 4" Exhaust from The Turbo Back
Isspro Gauges/above mirror gauge pod
Boost/Exh Temp/Trans.Temp
Isspro TTM
Black Dog Security
97 F250 Regular Cab 7.3
215,000 miles and still going
Almost Stock
NRA Life Member / NRA Cert. Personal Protection Pistol Instructor
Class 3 RSO
DIESEL POWERED ROCKET is offline
post #6 of 29 Old 12-02-2008, 01:19 PM
scotty2280's Avatar
yep no need for a turbo timer when u have a perfectly good egt gauge to look at!
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #7 of 29 Old 12-02-2008, 02:17 PM
I can tell you that ideling a 6.0 will bring lots of headaches, unless you take care of the EGR. After the EGR block off plate, I can leave the rig running for days on end with no problem. Without the block off plate, I wouldn't push it much past 15 minutes.
2004 F350 CC long bed 4x4
4" silverline turbo back, Airaid intake, Zoodad
2.5 skyjacker leveling kit with airbags in rear
Auto Meter pyro, boost, trans gauges
And one pretty red paintjob
"Is your truck broken???, No, it's stroking"
Crystal Creek is offline
post #8 of 29 Old 12-02-2008, 07:14 PM
I can tell you first hand it uses WAY more fuel to leave it idling. I do refrigeration service. When I first got my truck I let it idle all the time during the summer when I was doing service calls. I have to get in and out of my truck often to get supplies, write things up, make phone calls, etc. I kept it running so it would always be cool. After a couple weeks of 11 MPG averages, I stopped letting it idle and went up to over 16 MPG.
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #9 of 29 Old 12-02-2008, 07:18 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Kind of a dumb question but does a 7.3 have an EGR?
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #10 of 29 Old 12-02-2008, 07:18 PM
cchase's Avatar
I let mine idle all the time at jobsites, in the winter. I just hate having a cold truck, and I useally have lights going... plus it has the im important effect lol, and if im running into a store for a drink, i leave it on. no sense in turning it off for 5 minutes, and making the glowplugs and batterys wear out faster.
cchase is offline
