There has been quite a few of these lately in the shop for front ABS sensors which is weird because all we used to do was rear ABS sensors on these, anyway I made a quick video showing just how to change it out. Simple job but some like to see just how involved it is.
Can someone reply with the time it takes to replace the sensor?? My shop just did ball joints and the abs light came on. They said they are going to replace it but it will need to be there for two hours. That just seems like a long time but let me know if it actually takes that long
15 minutes, tops, including the time it takes to remove the wheel and put it back on..if you do it in your driveway.
You undo a couple plastic pieces that hold the wire to a couple spots, remove one allen screw, unplug the wire...reverse procedure.
If you can't pull this off, you need to hand over your man-card.
Ok thanks a lot guys. I don't know why they need the car for that long. Needed new ball joints and new rear brakes and calipers. They took it around the block and said abs light came on. Guessing they screwed it up. Wouldn't have taken my truck to their shop but it was the only place that would give me a certification sticker the way it is
If you have a hard code, -check engine light on or abs light on any code reader should report it.
Soft codes require a better device. I use forscan on my laptop with an elm327 usb adapter to read soft codes, because I am too cheap to buy anything else. :look:
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
