Edge insite help!!
I've got an 05 powerstroke and I just installed the sct (innovative) x3. Then I installed the edge insite for my gauges. I drilled and taped the manifold for my egt probe. I hooked everything up and my egt temp is not working. It reads N/A. All of the other temps work though. Could it be that my egt probe is bad or my box is bad? Pleas help. thanks
Try calling edge I had a problem with mine and they were very helpful.
The EGT the insite reads out of the box is a factory EGT. Since our trucks didn't come with one it doesn't show. You need to go into the settings and point it to the Edge probe and it will work.
since the last firmware update i have not ben able to get my trans temp to work.. has anyone ells had this problem?
I just installed an Insight in my '04 and my Trans Temp shows N/A, so I'm interested in an answer one this as well.
yep I got the N/A after the last firmware update.. And I don't thing my trans slip is working ether
I just got my truck out of the dealership and was updated to latest flash. The unit worked fine before going in now it wont even load up....oh and before that after I updated the unit as others above had done I got a N/A for the trans temp.....this is becoming very annoying....edge is gonna get an earful tomm after I get off of work...the unit is great when it works it just seems as time goes on it just has more and more problems... just my 2C...
