2005 Transmission drain/filter/refill question - Ford Powerstroke Diesel Forum
Old 11-28-2008, 12:55 PM
2005 F250 automatic -> drained, cleaned the pan, change the filter (in the pan)
.....how much fluid do I need to refill it? 7-8 quarts? Maybe?
Thanks in advanced.
Old 11-28-2008, 12:57 PM
Thanks in advanced.
if you drained all the fluid its 19qts for the total fill
Old 11-28-2008, 12:59 PM
Did you drain the Torque Converter and all?
Old 11-28-2008, 01:06 PM
I only drained the pan.
Old 11-28-2008, 01:07 PM
Send a message via AIM to 67ModStang Send a message via Yahoo to 67ModStang
Did you change the inline filter too?? That's the one that really matters
When I last did mine I only had to put 12 qts back in. Also make sure you use Mercon SP
Old 11-28-2008, 01:13 PM
Yup, changed the inline filter too. Got the Mercon SP fluid too.....purchased all of it from the Ford dealer.
I've put in 7 quarts so far.....and I can see the fluid on the dipstick. (I let in run for a while in Nuetral to circulate).....should I add more? Dont want to mess anything up.
Old 11-28-2008, 01:16 PM
you didnt rain the TC ? that thing holds a lot of fluid....
Old 11-28-2008, 01:17 PM
I would have drained the TC if i were you
Old 11-28-2008, 01:18 PM
You may be close, I'm not exatly sure how much the pan itself holds. I also let mine run for a couple seconds with the inline filter off to pump some extra fluid out. As long as you are checking on level ground with the engine running and are above the add line I would say you are good.
nah, just the pan this time.
