I have a 2003 F250 4x4 6.0 PSD with a build date of 03/2003 and I can't seem to find the right lug nuts. I ordered some 14mm x 1.5 and they didn't work but that is what all the application guides said was the right one. When I bought the truck it had the factory wheels and factory lug nuts on it so I konw it's stock. What other size could they be? I know the 02 and older had 14mm x 2.0 would there be a chance these are the correct ones? I have looked through other threads but haven't found the answer i'm looking for.
subscribed.
it might be a coarse versus fine thread problem. my 03 is coarse...
They have to make this crap so fricken confusing.
My late 99 has the course lugs and it takes the 14mm X 2.0's but when getting them think you still have to say fine or course thread
The 2.0 or 1.5 is the thread pitch.
03+ should use the 14mmx1.5 99-02 used the 14mmx2.0 |
That is what I have been reading but there lies the problem. I have a 2003 with a 6.0 and 14mm x 1.5 will not work on my truck. I know the charts say it should fit but it doesn't.
ok--can you kind of half-arsed thread the thing on, as in, is the diameter right and the threads will only catch for maybe1/3 to 1/2 of a turn?
if so, wrong pitch. if the thread wont engage at all, you have the wrong diameter nut. |
Anyway they are the correct diameter and they "act like" they want to start is what I was told. Does that mean I need 14mm x 2.0.
