06 Tow boss package? how do you know? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-26-2008, 07:54 AM Thread Starter
RamAirfreak98ss's Avatar
Quoted: 4 Post(s)
Garage
I have a shortbed dually 06 F350, i SWEAR it has 4.30 gears by how much higher the RPMs are compared to my 06 w 3.73s.
70mph on the 3.73s is almost 2k rpms
70mph on the dually 410s standard, 4.30s tow boss? 2400+
Without towing seems like its reving crazy. The rear diff cover has vanes on it "for cooling" i guess, is that standard
How can i tell by the axle code on the VIN # tag in the door?
What else does the tow boss package have besides the different gears?
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
post #2 of 6 Old 11-26-2008, 08:18 AM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
You can use this list and cross reference the code on the tag.. it only goes to 02 but it should still be the same...
If nothing else you can always pop the cover off and count the teeth..
Automotive What is my Ford rear end ratio, do I have positraction
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 6 Old 11-26-2008, 01:26 PM
350steve's Avatar
A gcvw of 26,000 lbs.the dif cover has the aluminum vane cover stock
from ford..My truck 06 6.0 cc drw fX4 4.30 tow boss
06 6.0 F-350 DRW CC 4X4
95 F-350 460 western ultra mount pro plus
member of the lazy over paid plow operators of America
350steve is offline
post #4 of 6 Old 11-26-2008, 04:25 PM
Yea, what he said:
The tag on the diffs... Mine has 410 as the first three numbers, 07 Dually KR CC 4x4...
And I am running about 2250 RPM at 70 miles/hour just over 110 km/hr...
Regards from Australia.
Lone Ranger is offline
post #5 of 6 Old 11-26-2008, 04:28 PM
jamstoyz's Avatar
sounds like you have 4.30's cause my rpm's are the same you just pointed out at 70 mph.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #6 of 6 Old 11-26-2008, 06:03 PM Thread Starter
Quoted: 4 Post(s)
Garage
Yeah, its got an axle code on the door "4L" which appears to be a LSD type rear, thats not on the above list i guess because its an 2006 model.. anyone know what the 4L is then?
So the tow boss package is 4.30 gears , the aluminum vaned diff cover, how much was an option like this when new? Ive only briefly heard of it back when i got my first 06 but never saw a truck optioned with it.
04 F350 XL
