Gear Lube: Mobil 1 or MotorCraft? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-25-2008, 09:26 AM Thread Starter
JBakerFX4's Avatar
Called my local dealer for some prices.... $21.04/qt for the 75-140 syn gear lube!!!! I can get Mobil 1 75-140 for $16.99/qt. Which do you guys think is better? They want $4.99 for the LSD additive and $22.50 for the cover sealant!!
'09 Tacoma CC/SB, TRD Off-road.
NRA member
One Nation Under GOD!
JBakerFX4 is offline
post #2 of 8 Old 11-25-2008, 09:32 AM
PSD
ROYAL PURPLE OR AMSOIL OR SCHAEFFER'S THE BEST
outlawdiesel is offline
post #3 of 8 Old 11-25-2008, 09:33 AM
Raul@Stealth Automotive's Avatar
agreed.... pref Amsoil severe gear
Raul@Stealth Automotive is offline
post #4 of 8 Old 11-25-2008, 09:57 AM
I'm in the same position, I went around town looking for some gear lube, best deal I can find was at Wally's, it was like $7 a bottle for synthetic but they didn't have it in 75-140!...and Mobil1 is 16.99...im just going to order up some Amsoil, its the same price as mobil1 or valvoline....actually cheaper if you have a premium membership with them.
Early 99 F250 4x4 CCSB w/ LATE 99 engine
- TW Chip, 5" straight exhaust, DIY intake w/ Amsoil 4095 filter, Gauges, ITP Pre pump filter and tank mod, Riffraff IC boots, AIH delete, EBPV delete, Foil delete, 3" lift on 35" BFG KM2, , custom rear bumper, Lightforce 170 lights
Blasterak is offline
post #5 of 8 Old 11-25-2008, 10:17 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Royal Purple doesn't require the LS addititive and has been working just fine for me.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #6 of 8 Old 11-25-2008, 12:33 PM Thread Starter
JBakerFX4's Avatar
I don't know man... Botique oils. I might look into the Royal purple.
NRA member
post #7 of 8 Old 11-25-2008, 01:23 PM
Your truck is like brand new dude!!! How many miles? I didnt change mine till 60000. But maybe, switching to a heavy full synthetic is the way to save the axle and gears for the long haul. One suggestion, go and add an aftermarket cover. Aluminum will shead the heat much faster than steel. I hear that the '08 Superduty finned aluminum cover will fit earlier axles. I don't think it holds extra fluid, but with the extra finns and cooler running temps, you should be good to go. Dawg nabit!!!! Now I want to change my fluid. SEE WHAT YOU STARTED!!!! Good luck.
2004 F350 CC long bed 4x4
4" silverline turbo back, Airaid intake, Zoodad
2.5 skyjacker leveling kit with airbags in rear
Auto Meter pyro, boost, trans gauges
And one pretty red paintjob
"Is your truck broken???, No, it's stroking"
Crystal Creek is offline
post #8 of 8 Old 11-25-2008, 01:31 PM Thread Starter
JBakerFX4's Avatar
haha.. yea i have 17k on my truck. What started all this was I was doing my inspection checklist items which I'll admit haven't been doing and checked the rear fluid gear lube and it looked like crap and I found a piece of metal stuck to the magnet. So I had to pull the cover off to inspect the teeth and sleep easy.... turns out the gears look great, the spider gears look good... everything looks fine. So I'm assuming it was a piece of assembly debre. So I put 80-90 Semi Syn Valvoline in it for the time being.... see how it looks in about 3k miles. But I'm planning on doing the 2008 Cover, with the Ford sealant. Just not sure what 75w-140 to run, and if the LSD additive is needed.
NRA member
