Back to puking after gaskets and studs.....
I did head gaskets and studs on a 06' truck. I started puking around 20k miles and slowly got worse. I did gaskets and studs around 35k miles. About 40k I noticed a little bit of puking and its slowly getting worse again......I deleted the EGR when I did the studs and gaskets.
What could cause this? Warped heads/back deck on the block? I just dont know what direction I should go with this thing now
I think you may be on the right track with the warped heads,,
From what I had read in the past their is basically no tollerence to have them decked; is that correct
There is a VERY small tolerence. I think the minimum deck height for the head is 3.75". Usually you can clean them up if they haven't been cut before, but I wouldn't go more than .006 or .008.
