what is this? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-23-2008, 01:49 PM Thread Starter
js250's Avatar
what is this?
there is like a little pump i think on the passenger side of my truck that always comes on when i first start my truck it has an orange electrical connection on it Help
js250 is offline
post #2 of 6 Old 11-23-2008, 01:58 PM
pitamarillo84's Avatar
i believe it is the supplementary vacuum pump that you are hearing but i not 100% sure
pitamarillo84 is offline
post #3 of 6 Old 11-23-2008, 06:43 PM Thread Starter
js250's Avatar
what does it do?
js250 is offline
post #4 of 6 Old 11-23-2008, 06:49 PM
take a photo, sounds like it could be the vacuum pump.
If it runs constantly, you probably have a leak somewhere.
take a pic tho
I'm a wh0re for free stuff
kinghawg98 is offline
post #5 of 6 Old 11-23-2008, 07:57 PM
lawman349's Avatar
Originally Posted by js250 View Post
what does it do?
It controls anything the normal vacuum pump would- like the vent/defrost position for heat and ac. Also controls the ESOF mechanism for the 4x4s that are equipped as such.
2003 F350 SRW CC 4x4 6.0L
Coolant Bypass Filter w/ Cat ELC
Amsoil Oil Bypass Filter
Hypertech MaxEnergy / Bully Dog Outlook
Cat and muffler DELETE!
Icon 2" leveling kit
Mickey Thompson MTZs
ARP Head Studs / New Ford OEM HGs
New heads
Sinister Diesel EGR Cooler
Blue Spring Upgrade
New HPOP STC connection
lawman349 is offline
post #6 of 6 Old 11-23-2008, 08:04 PM
back in the saddle
shu873's Avatar
Yeah, its the vacuum pump. I'm not the best at explaining this, but if you'll notice on a gasser motor all the vacuum lines used to run brakes, etc. are run to the intake where they get that vacuum. On a diesel it doesn't work that way which results in needing a supplemental pump to operate various things.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
