electrolysis voltage for our trucks? - Ford Powerstroke Diesel Forum
Old 11-22-2008, 11:38 AM
I put one lead of the volt meter on the Battery Neg terminal, and the other lead in the coolant. .14V DC is what I got. Tested it numerous times with 2 different meters. .14V DC with truck off and on. Is this within range?
Old 11-22-2008, 12:09 PM
uh why are you doin that?
just test the pos to neg with the meter
Old 11-22-2008, 12:23 PM
b/c that's how you check for Electrolysis. One lead in the coolant, other lead on the Battery Neg. I found a TSB that says .4V is the limit.
Old 11-22-2008, 12:47 PM
ok
so if you get .14v
and limit is .4
what does that mean?
Old 11-22-2008, 02:54 PM
I'm under the .4V limit. Should be A OK.
