Heater Question - Ford Powerstroke Diesel Forum
Old 11-20-2008, 05:45 PM
Heater Question
I have noticed that my truck won't warm up very well just left to idle. Then when i'm driving i noticed that the air will actually start blowing cooler when I stop at a stop light and then warm back up really quick when I take off. Is this normal for the 6.0s. Also does anyone know why the climate control says A/C when it is heating not cooling?
Old 11-20-2008, 07:29 PM
about the A/C mine dose the same when i turn the temp up for heat the direction changes to the floor but the A/C stays on till i manually hit the A/C button to turn it off...
Old 11-21-2008, 05:09 AM
heat/cold
you may be low on anti-freeze
Old 11-21-2008, 06:53 PM
It is below the antifreeze min mark but not terribly low.
Old 11-22-2008, 06:08 AM
fill it up
top it off and see if that helps
Old 11-24-2008, 05:24 PM
I topped it off yesterday. Today when I got to work I saw something wet on the spring and suspension. I looked under the hood and found the degas bottle was well below the min level. Does the cap on those go bad like a radiator cap can? I didn't fill it above the max level and it was a cold engine.
Old 11-24-2008, 05:29 PM
duct tape & zip ties
find the leak and repair it.
