Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 11-10-2008, 06:34 AM
henryrski henryrski is offline
2005 6.0 busted
300 miles into a cross country trip and my 05 F350 6.0 dies on the road. Towed it to the dealer and get a call saying "high pressure oil leak" and they do not know how long it will take to fix. Anybody have any experience in this issue? I read it is all integral, saw some posts about leaks at the flange of the pump, But I would like to continue my journey and have no idea when I will get my truck back. Any insight would be appreciated.
Old 11-10-2008, 07:00 AM
tech10002 tech10002 is offline
There's a line with a banjo type fitting on it that feeds the stand pipe going to the high pressure rails. I think that's a fairly common place to have high pressure leaks. There are a bunch of things it could be, though. How long it will take depends on how competent their techs are and how busy they are. Unless you're lucky enough to be broken down in Winston Salem, that's hard to say.
I wish I could be more help. Maybe Scuffy or Jon will see this and can tell you more.
Old 11-10-2008, 10:35 AM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
happens all the time. if their tech is capable they will have you on the road soon.
Old 11-10-2008, 03:24 PM
JBakerFX4 JBakerFX4 is offline
Anyway to avoid this happening since it happens all the time?
Old 11-10-2008, 03:39 PM
scotty2280 scotty2280 is offline
holdmybeerandwatchthis
dont drive your truck
Old 11-11-2008, 08:32 PM
forddieseldoctor forddieseldoctor is offline
Powerstroke Techie
Location: Saint Cloud, WI. yes there is one in Wisconsin.
too bad your not in door county wisconsin. i need the work. kinda slow here. good luck.
Old 11-12-2008, 12:45 AM
bismic bismic is offline
The only way is to proactively change out the "Snap-to-Connect" fitting w/ the upgraded part.
Old 11-12-2008, 05:40 AM
BIG RED84 BIG RED84 is offline
THE NEW STYLE STC FITTING THAT FORD JUST CAM OUT WITH WILL ELIMINATE THE NEED FOR PROACTIVE REPLACEMENT OF THAT PART!! INSTEAD OF USING AN O-RING, THE HAVE JUST MADE IT WITH A JAM NUT. THIS WILL HELP PREVENT IT FROM DYING ALL OF THE TIME. THAT IS THE MOST COMMON PROBLEM WHEN THERE IS A HIGH PRESSURE OIL LEAK. ANY GOOD TECH SHOULD HAVE IT DONE WITH IN A DAY!! ALSO, IT COULD BE THE D-RINGS ON THE DUMMIE PLUGS IN THE HIGH PRESSURE OIL RAILS. SOMETIMES THEY HAVE A TENDINCY OF GETTING CUT. IF THAT'S THE CASE, THEY WILL JUST HAVE TO WHIP THE VALVE COVERS OFF AND GET THOSE D-RINGS REPLACED. A FEW HOURS MAX FOR THAT REPAIR. (IF THEY HAVE A DECENT TECH!!)
Old 11-12-2008, 07:30 AM
rbloodhound rbloodhound is offline
Do they have you up and running yet?
