What is a normal oil temperature in frigid temps? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-23-2014, 05:58 PM Thread Starter
I live Indiana where the heat wave continues at 5 degrees and windchill at -20 degrees. I noticed my oil and water temps barely get to 170 degrees while driving for an hour. I get mixed answers from service techs at multiple shop when they say, "bring it in and we can check it over $110.00 an hour. I running Rotella T6 5w40 with a coolant flush about 3,000 miles ago. My Scangauge tells me all vitals are good, but it can't hurt to ask.
rhillman75 is offline
post #2 of 14 Old 01-23-2014, 06:07 PM
F250SixOH's Avatar
Just replace your thermostat and run some cardboard in front of your radiator. Your thermostat seems to be stuck open but then again it's cold as heck. $30 and 30 min is all it takes to replace it. I would try the cardboard first though and see what happens.
F250SixOH is offline
post #3 of 14 Old 01-23-2014, 06:14 PM
work&play's Avatar
Quoted: 2 Post(s)
It has been the same kind of cold in CT.
My truck has been running about 5-10* lest then normal also.
ECT about 175-180* and EOT 170-180*
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #4 of 14 Old 01-23-2014, 06:26 PM
wired1's Avatar
Are you guys running stock oil coolers? As my ect are around the same as what you are seeing ,but my eot is 150-160 on the high side in low teens / single digit temps. I'm going to do the cardboard trick next time it gets cold around here. right now in the 40's I see 180-190 on both
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #5 of 14 Old 01-23-2014, 06:31 PM
eurotrashb5's Avatar
Ovah here in NH at a balmy 2* right now I'm running my 5w40 at 190* but my coolant won't get over 180*-182* stock egr/stock oil cooler. I think I may have some sort of issues myself. Off the highway my oil drops between 185*-190*
Enough with the stacks already...
06 F250 6.doh
Fox-body mustang mini stock w/ a 250ish rwhp 2.3L
99 CCSB 7.3 F250 - 4"MBRP turbo-back, 6637, Procomp wheels, 33s, Skyjacker leveling kit & rear add-a-leaf -- SOLD
03 SVT Focus -- SOLD
97 F350 EXLB Dually 7.3 -- SOLD
eurotrashb5 is offline
post #6 of 14 Old 01-23-2014, 06:42 PM
kdogg85's Avatar
Wired, in the 40 degree outside temps, both should be 190 or higher.
Guys, it's around 8* here! my wife's truck is running in the low-mid 180's. It's just where it's cold and the barn door radiators these trucks have are doing their jobs. You can do the cardboard if you like, but 180* isn't going to hurt anything.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #7 of 14 Old 01-23-2014, 07:35 PM
DieselV8's Avatar
It was -30 here yesterday and my eot was 184 and ewt was 177 and that was with cardboard in the front.
06 F250 Crew Cab, Lariat-FX4, ScanGauge II, High idle mod, Heated mirror switch mod, Sinister bypass oil filter and coolant filter, Fumoto valve, Zoodad, Blue Spring
DieselV8 is offline
post #8 of 14 Old 01-23-2014, 07:48 PM
kcoyner's Avatar
Quoted: 57 Post(s)
At 5 degrees this morning my EOT settled in at 198 and would go up to about 201.
My ECT was running 188 to 192.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #9 of 14 Old 01-23-2014, 08:58 PM Thread Starter
Tell me about it. This is the worst winter I have seen in 5 years in Indiana. This polar vortex is kicking our a$$. I kind of figured I was worried over nothing since mother nature has put her thumb on us, but getting the same answers help. Although, I never thought about the t-stat, so I am going to replace it since I don't know really how old it is. So much for not buying a snow plow... my neighbor has banked over $12,000 in contracts in the last 30 days. How in the world are you guys running at 20 degrees higher?
post #10 of 14 Old 01-24-2014, 09:09 AM
phlegm's Avatar
I have not run any cardboard and here in Fargo ND, its been cold as hell all winter. at the interstate speeds (75-85mph) and temps down to -27f I've been able to keep it above 180f (ECT) I did replace the thermostat with a motocraft unit. But I'd love to get that ECT up in the mid to high 190f range.
This graph is from 12/23 when the cold temps ranged from -25.5f to as warm as 3.2f during a single trip. I don't thing it actually was 3.2f, that must have been a false reading from when I was sitting and idling or something similar. I included GPS speed for reference.
I think for next year, I'm going to buy a spare XL grill and get a zip up cold front.
2005 F250 CCSB Lariat with FX4 6.0L leveling kit, engine stock for now
phlegm is offline
