Yes or No??? Need help quick!!!
I'm going to have a leveling kit put on this afternoon. The guy at "We do trucks" said the kit he is putting on does not need a front end alignment afterwards. What do you guys think???
What kinda kit??
Skyjacker.........
I was always told whether you raise or lower the suspension you are changing the front geometry and you should get a alignment.
I would think yes, but I don't know much about that , but it stands to reason.
I would just to be safe. As expensive as tires are it is just good insurance.
I would say yes you do because you don't have the solid axle. If you don't want to spend the money just keep an eye on your tires and if you see any abnormal wear in the next 5k miles or so then you should get the alignment done.
Yes he does have a solid front axle if it is 4X4 even the 08's have solid front axles
i say yes! its only 70-80 bucks around here and those tires you put on there are atleast worth that in the long run
i wouldnt absolutely think you would..your only putting a spacer above the spring...its cheap though just do it to be safe
