which way to go - Ford Powerstroke Diesel Forum
Old 10-08-2008, 07:25 AM
which way to go
if i stud my truck do i just put stock gaskets on it or do i get something different. why does hypermax saysa if you put their gaskets on dont stud it . i need to know because head gaskets are leaking for the 5th time
Old 10-08-2008, 07:29 AM
Thats Mr. Oil Leak.....
From what I understand the stock gaskets are really good. If you stud it with stock gaskets you should not have a problem.. but I'm not sure. I'm a 7.3 guy..
Old 10-08-2008, 07:30 AM
I wanna go fast!!!
Everyone i have seen has just studded it and just used the factory gaskets.
Old 10-08-2008, 07:44 AM
<-Day Of Fail now SOLD
Just go with new factory gaskets and a set of studs. Should be fine after that.
Old 10-08-2008, 07:55 AM
Make sure they are checking the heads to make sure they are flat. If you have a warped head and they are just putting a new gasket on it then it will leak again. But if the heads are flat, stud it with stock gaskets and you will be fine.
