Another Wheel Question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-02-2008, 04:26 PM Thread Starter
axe124's Avatar
Sorry if this is in the wrong section. First time posting.
Just bought a 2004 F250 Crew Cab. Will 18" wheels fit, even though I have stock 16" now??
When I owned an 04' f150 it had stock 18" wheels. When the lease expired, I returned the truck, but kept the 18" BFG A/T tires. Now that I have an F250 I would like to find some 18" wheels for it.
Thanks,
Scott
axe124 is offline
post #2 of 9 Old 10-02-2008, 04:28 PM
1995psd's Avatar
what size tires?
1995psd is offline
post #3 of 9 Old 10-02-2008, 06:23 PM
DCSpecial's Avatar
Also, what's the load rating on the tires that you pulled off of the F-150?
You can bolt 18s with the right bolt pattern and back spacing up no problem.
Tire size will determine if the combo fits under the truck.
DCSpecial is offline
post #4 of 9 Old 10-03-2008, 05:26 AM Thread Starter
axe124's Avatar
Thanks for the responses...the tire that I have is a BFG A/T (LT 285/65R18) Load Range D.
Scott
axe124 is offline
post #5 of 9 Old 10-03-2008, 05:52 AM
jcmer22's Avatar
those will fit under a stock truck and look stock. my tires are 275/70/18
jcmer22 is offline
post #6 of 9 Old 10-03-2008, 09:12 AM
DCSpecial's Avatar
Should fit with the right wheel width and proper backspacing.
post #7 of 9 Old 10-03-2008, 02:55 PM Thread Starter
axe124's Avatar
So where's the best place to find 18" wheels for the tires I listed above?
axe124 is offline
post #8 of 9 Old 10-04-2008, 12:03 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Just shop around, most wheel companies will have 18x8" with an 8 on 170mm bolt pattern and 3-1/2" backspacing which should work fine on your truck with those tires.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #9 of 9 Old 10-04-2008, 06:10 AM Thread Starter
axe124's Avatar
Thanks to everyone's replies....let the shopping begin.
Scott
axe124 is offline
