Weird noise. Want to make sure its not serious - Ford Powerstroke Diesel Forum
Old 10-01-2008, 05:24 AM
So I didn't want to title the thread "strange noise" because no one will look at it.
However recently, as in for about 2 weeks when I drive the truck with the windows up, music off and A\C either off or on the first notch I get this strange noise from somewhere in the truck. I am assuming its from the front since I can hear it.
It sounds like little birds chirping, quickly and in a very hi pitch. It does it the same speed if I am slowing down, speeding up, and cruising. Something needs lubrication? I just want to address it now rather than 12 hours away from my garage pulling 12k lbs.
Thanks
Old 10-01-2008, 05:37 AM
Im thinking that it's a possibe u-joint that might be starting to fail. Your factory u-joints do not have a grease fitting. The only way to fix it, is to replace it. 9 times out of 10, the rear u-joint is the first to fail(the one on the yolk), then work your way forward by checking the other u-joints. In an extreme case, my F-150 had plenty of slop when I twisted the drive shaft back and forth. On my F-350, theres was no slop, but I replaced it, and cured the problem. -Trevor
Old 10-01-2008, 05:40 AM
so vehicle speed has nothing to do with the sound changing ?
may be the blower motor, is the noise present when sitting still ?
Old 10-01-2008, 05:48 AM
Yes, sitting still or cruising all the same.
Old 10-01-2008, 05:54 AM
Hmm, Im gonna shoot some WD-40 in them suckers and ride around for a min and see what it does.
Old 10-01-2008, 10:22 AM
Turn the radio back on and you wont hear it!!!
(wow,some of these tech problems are EZ !)
seriously...i suspect the blower also.
Old 10-01-2008, 02:19 PM
u-joints don' rotate/move sitting still.
the WD-40 will probably just wash out whatever grease left in them
Old 10-01-2008, 02:40 PM
I tried it again today, they might actually be the ujoints. I started the stop and start game to see if I could isolate the noise, and I am just hearing it when I am sitting because I hear it all the damn time and its stuck in my head lol
Old 10-01-2008, 03:44 PM
LOL, i understand....good luck and let us know what you find
Old 10-01-2008, 04:40 PM
Blitanicle99, on both of my Fords, the noise from the u-joint slowly got worse and worse. But on my friends Chevy Avalanche, his u-joint started to act up, and within a 2 week period, I couldn't belive how much louder it got in that amount of time. I pulled an 8000 lbs every Friday during the summer with my F-150 that had a bad u-joint.(not smart I know) You should be able to make it back to your garage without an isssue. Of course if you did break a u-joint, put your truck in 4wd to get to a safe spot,(I'm sure you knew that already.) Hope this helps you sort out your issues. -Trevor
