2006 F-250 rear end gear - Ford Powerstroke Diesel Forum
Old 09-30-2008, 02:39 PM
Went looking at a used 2006 F-250 today. the rear end code is 3L. what is the gear ratio ? I kinda thought that the f-250's mostly came with 3:73 but the dealer told me this was 4:10 and most of the 250's are 4:10. I figured I ask you all.
Old 09-30-2008, 02:43 PM
3.73 with limited slip. There should have been a 73 after the 3l if you were looking at the tag on the rear end.
Your dealer is wrong. Its the other way around.
Most F250's have the 3.73
Old 09-30-2008, 04:20 PM
The only way to get 410's in a 06 f250 Diesel is to get a dually. All of the SRW's are 373's
Old 09-30-2008, 04:22 PM
Send a message via AIM to jhaddox
is that the same for 350's? always thought i had the 3:73 but wasnt sure
Old 10-01-2008, 06:08 AM
Originally Posted by bigd4x4 View Post
The only way to get 410's in a 06 f250 is to get a dually. All of the SRW's are 373's
So you had to replace your 3:73's with 4:10's or where you able to order them with the truck as an option ?
Old 10-01-2008, 06:30 AM
Had to replace mine.
Old 10-01-2008, 09:50 AM
IIRC Gas motor trucks can get the 4.10 gears as an optional gear in the SRW configuration.
Old 10-01-2008, 10:14 AM
thanks for the help you all !!.. i guess all the research I've done has kind of paid off, because i was quick to write that truck off.
also, i got to see the oasis report and it looks like a few gaskets and a couple of other things had already been replaced under warranty for a 15,000 mile truck.. I hope it has all of its problems out of its system for the time being !!
Old 10-01-2008, 10:17 AM
Your absolutely right but didn't think I had to add diesel to my description since we are on powerstroke.org
