Cleaning under the hood - Ford Powerstroke Diesel Forum
Old 09-30-2008, 08:37 AM
My under hood area is a little dusty and grimey. How can I SAFELY clean up everything?? (w/o using a weekend and a toothbrush)
Old 09-30-2008, 08:41 AM
a car wash works great just spray the whole under hood with simple green and get to washing.
Old 09-30-2008, 09:12 AM
thanks!!!!!!!!!!!!!!!!!!!
Old 09-30-2008, 09:13 AM
a truck
Use simple green then hose it all off. I went mudding and under my hood was completely brown sprayed it down with simple green a lot and hosed it down and it cleaned it all up
Old 09-30-2008, 09:44 AM
International Threat
I like to stay off of the relays and alternator.
Old 09-30-2008, 10:06 AM
After it dryies, spray some shiney stuff on it and then wipe it down with a towel.
Old 09-30-2008, 10:27 AM
Diesel fuel spray a bit on everything. leaves it shiny and cleans it very well
Old 09-30-2008, 10:52 AM
Inside the users manual they show the areas to cover to prevent water intrusion. Alternator, batteries, and LH fuse/relay box off the top of my head.
Spray with water first, then use a degreaser, let it sit for a few minutes, rinse. Repeat as necessary.
Old 09-30-2008, 11:21 AM
If it's really nasty go to the store and buy a can of cheap oven cleaner spray it let it sit for five min. then wash it off with low pressure water. This works great for the areas with lots of oil and dirt sticking to things.
Old 09-30-2008, 11:25 AM
Send a message via AIM to SteveKran Send a message via Yahoo to SteveKran
Purple Power works great for me....I just use it with the garden hose and a spray nozzle. Clean as a whistle every time!
Make sure you don't do it while the motor is hot....rapid cooling/heating of metal could cause thermal embrittlement which could lead to cracking. If I clean under the hood, I do it first thing in the morning and then leave the hood up to dry.
